Fork seal change, help please!
- anotherZ
21 Sep 2013 11:30
So I took the legs out but I don't get the Allen bolt at the bottom of the fork leg out (the one that holds the inner piston). The Clymer says that you "may need a Kawasaki special tool to prevent the damper unit from turning". I have turned the Allen bolt multiple times and can tell that something on the inside of the fork is turning as well. So what can I do?
Bike is a 1979 LTD. Thanks for any help!
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
Smaller tank
- mp-43
Re: Fork seal change, help please!
28 Sep 2013 01:30 - 28 Sep 2013 01:36
Never mind - saw this got answered all over the place in another thread.
Last edit: 28 Sep 2013 01:36 by mp-43.
- anotherZ
04 Oct 2013 10:39
Yes, sorry, had accidently posted twice....
79 KZ 1000 LTD
Smaller tank
Smaller tank
- Britbiker
14 Oct 2013 01:21
I can help by now you may have solved this problem I had a week ago you need a long bolt maybe 4 /6 inches you lock onto the end a hexagonal nut then using every extension bars you can find to make it a foot or more long gently insert this down the tube your allen key is fixed on the bottom then you can turn one or the other against each other,unscrews easy
IF you look down the tube with a powerful torch you can see what looks like a hex socket . I can find you the size metric the tool i made is in mygarage not sure if you still need it now ,let me know Keith
- anotherZ
16 Nov 2013 20:08
Just saw this now, I am good, thanks! Made my own hex tool.
79 KZ 1000 LTD
Smaller tank
Smaller tank
