kz750 cylinder head nuts - change
- undiablo
18 Sep 2013 13:02
Hello guys!
My engine is running very nice now, so I am doing some fancy cleaning and chrome.
The original cylinder head nuts (
are pretty old by now and the chrome is fading.
The nut is still available from Kawasaki, the question is:
Can I remove one nut and replace with a new one, and so on until the 8, applying factory torque with out the risk of a gasket leak?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Nebr_Rex
Re: kz750 cylinder head nuts - change
18 Sep 2013 13:25
Yes, and retorque the head after a heat cycle.
And use some lube on the threads for a proper
torque reading.
torque reading.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: undiablo
18 Sep 2013 17:13 - 19 Sep 2013 00:34
To anyone who might be unaware, re-torquing after a heat cycle means first getting the engine up to normal operating temperature, and then allowing the engine to cool until it's stone cold (as in leaving the bike parked overnight), and torquing the head fasteners on the stone cold engine (in the tightening pattern as specified in the Factory Service Manual a/k/a "FSM").
I don't use any lube incident to the re-torque.
Last edit: 19 Sep 2013 00:34 by Patton.
- undiablo
18 Sep 2013 20:14
Thanks for explanation Patton... was just about doing it the wrong way.
I should read more!
I should read more!
- RonKZ650
19 Sep 2013 00:14
They have used 3 different nuts for the head over the years, I forget the exact names, but the first one was the one with the bulged top, quickly discontinued, then on the KZ650 they had the tall chrome head nuts on the outer bolts and the inners used flanged open nuts. Probably by 1980 they used all the tall chrome nuts if that is what you are after and still available I'm surprised, they used the flange nut over the years in many models for many purposes. I like the look of the open nut better than the 1.5" tall things.
