Cylinder Head work
- freakinbike
Cylinder Head work
17 Sep 2013 23:11
One of my valves on my 1982 gpz750 has no clearance. I've posts about this before so I apologize, just seeking clarification. I still have no clearance after a valve adjustment, so the manual tells me to cut grind the valve seat and check the valve stem height. The manual goes on to say that if these do not give proper clearance then I need to get a new valve or new head, or both.
Even if grinding the valve stem gives me good clearance, I'm skeptical about how much compression I'll have on that cylinder.
My idea is to simply take the valves along with the head to the machine shop and have the grind all the valve seats and stems, and any other head work I'll need, since I can't simply buy a new head.
My question: is this kind of work possible? Like if I need material added to the head? And if it is possible, would it be worth it? Or am I just going about this all wrong?
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
1973 VW Bus
- Motor Head
Re: Cylinder Head work
17 Sep 2013 23:17
The machine shop should be able to do a valve job, at worst they may need to replace a sunken valve seat.
Take it to a shop that does bike heads, or at least an auto machine shop that knows about installed height and shims. A lot of cars have this also.
- MDawnz1
18 Sep 2013 01:58
Wrong ???,sideways maybe.
If you are going to spend that much $$ on a machine shop.
Why not just buy new SS valves and have a good valve job done and forget about it for the next decade or so?
Mike
PS don't GRIND the valve seats, have them cut.
After "grinding" the seats and the valves, it will lower the compression just a bit.
Mike
1974 Z1a, still 903
- Garn
19 Sep 2013 02:23
FreakinBike, you may only need what they call a valve "tip", which is grinding off a small amount of the valve stem end, making sure you do not effect the keepers.
A good head-shop would be able to advise.
You always need clearance between the valve and the cam when the valve is closed, otherwise ... you will loose compression and burn the valves. Often grinding the valve face you loose the clearance!
RegardZ.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
- baldy110
19 Sep 2013 13:07
Before you go tearing into the head have you used the smallest shim available?
- slayer61
- KZR FLAG RELAY CARRIER #62
19 Sep 2013 14:10
How much can be machined off the tip of the valve on a KZ/GPZ? The reason I ask is, a fellow flattrack racer performed a similar machining service on the tip of a Yamaha 500 valve and found out, too late, that he removed all the hardfacing from the tip of the valve! :pinch:
- Cynjut
19 Sep 2013 16:06
It's not much. A few thousands of an inch. Too much and you suck a valve.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- Lt.Dan
21 Sep 2013 17:21
My guess if it's an exhaust valve it's fried, if it's an intake valve the valve is being pulled into the seat and may be cupped. I have seen the seats coming loose on Hiway Patrol bikes exhaust valves but not too much on street bikes. That valve and seat need a real close examination before tip grinding is done.
