Cylinder O-ring question, KZ750 twin
  • pbmax
  • pbmax's Avatar Topic Author
17 Sep 2013 16:09
#606814
kz750 b4 twin
This is the original coming off.
This is the Vesrah replacement.
My question is, does this o-ring need to be "tucked" into the grove around the barrel? That's what I did. Otherwise it was a little bit loose and I didn't want it to interfere with the gasket surfaces.
I don't think the original was tucked as far down as I mine is. Maybe the original is a little thicker?
  • bountyhunter
  • bountyhunter's Avatar
Re: Cylinder O-ring question, KZ750 twin
17 Sep 2013 18:11 - 17 Sep 2013 18:13
#606829
I think it is supposed to fit into the groove. I am not entirely sure what that O ring is supposed to seal?
Last edit: 17 Sep 2013 18:13 by bountyhunter.
  • pbmax
17 Sep 2013 18:35
#606832
Even though its a tight fit, maybe it keeps oil from seeping between the sleeve and aluminum block...
