Mistake in KZ750 B4 manual? Help please.
  • pbmax
  • pbmax's Avatar Topic Author
17 Sep 2013 12:18
#606790
Part# 1 = 92043-1266 pin,11x14x12.3
Part# 2 = 92055-093 "O" RING
I'm 90% sure the pin should be a simple knock/dowel pin that goes around the base of the front two studs just like my red arrows show. It should NOT be used in this particular oil passage. The o-ring as shown should be correct.
Is this right???
There is an oil passage pin, but that is used on the top side of the cylinder barrel...
Thanks!!
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Mistake in KZ750 B4 manual? Help please.
17 Sep 2013 14:07
#606794
It is hollow, just a small diameter piece of tubing to locate the part in the proper location.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • bountyhunter
  • bountyhunter's Avatar
17 Sep 2013 15:22
#606803
Is this right???
Thanks!!
I made a picture from the Kawi manual showing the location of the pin and the O ring. They are not the same place.
The following user(s) said Thank You: pbmax
  • pbmax
17 Sep 2013 15:39
#606805
Bingo! Thanks!
