exhaust stud removal
- Kruulish
16 Sep 2013 13:00
what is the easiest way to get out exhaust studs? im trying vice grips right now and its not moving. bike is a 77 kz650b
- StreetfighterKz
Re: exhaust stud removal
16 Sep 2013 13:05
Heat will most likely be your best friend. A propane torch may work but MAP or Oxy/Acetylene will probably be better.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 4TheKZ1000
16 Sep 2013 13:17 - 16 Sep 2013 13:18
penetrating fluid.....heat.....vice grips......stud removal tool.....weld a bolt onto the end of the old stud.
Don't get on the bolt a torque the chit out of it......move it one way then the other in very small increments. Once it moves oil it and go slow back and forth.
If you try to go at it one way hard you could break the boss or casting off.
Last edit: 16 Sep 2013 13:18 by 4TheKZ1000.
- testarossa
16 Sep 2013 13:21
Rather than using vice grips you might try using jamb nuts if there is any thread left. That would allow you to get a proper wrench on there to apply more turning force.
Also, you may apply some penetrating oil to the stud and allow it to sit overnight prior to removal. If all that fails, heat up the area around the stud with a torch. Also it is possible to weld a nut to a broken stud for removal. Usually the heat from welding helps to break the offending stud loose.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
16 Sep 2013 13:50
I would use heat, a penetrant, & vibration.
heat -->> propane torch
pentrant -->> Kroil (best) or Liquid Wrench (good) -->> apply & let it work overnight
vibration -->> wood block & a mallet -->> it may be too late but install a couple of nuts on the stud to help absorb the impacts & protect the stud.
The following user(s) said Thank You: Cynjut
16 Sep 2013 13:57
For sure I would soak it with Kroil for a couple days before even trying to remove it. Ed
