engine tear down help
  • bleedgreen1990
  • bleedgreen1990's Avatar Topic Author
15 Sep 2013 18:54
#606560
ok so ive done ALOT of work since i last posted here. i have some questions since ive never done an engine before. i need to split the cases so i can clean them all up replace gaskets and paint. my question is this: do i split it right side up or upside down? and do i need to remove any more parts? i have the sprocket inner cover romoved exposing the linkage. the timing cover pulled back, and the clutch removed.
and i assume i need to remove the rest of the pistons
1982 kz1000
2004 zx10r
  • bleedgreen1990
Re: engine tear down help
15 Sep 2013 18:57
#606561
and if anyone has any how to or pics of engine dissassembly and reassembly tips id appriciate it
1982 kz1000
2004 zx10r
  • Nebr_Rex
  • Nebr_Rex's Avatar
15 Sep 2013 19:19
#606567
Go buy a manual, it's all in there. :woohoo:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • bleedgreen1990
15 Sep 2013 19:43
#606578
its actually not. the answers to the questions i asked above are not
1982 kz1000
2004 zx10r
  • Nebr_Rex
  • Nebr_Rex's Avatar
15 Sep 2013 19:53
#606582
Pull the head and barrels first ,then flip the cases upside down to remove the bottom.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • KZErider
  • KZErider's Avatar
15 Sep 2013 19:57
#606585
Telling someone to get a manual because "it's all there" is not what this forum is about.
When I don't have an answer I just mind my own business and let someone who knows what they're doing help the the poster with the question.
Sometimes the less experienced of us need a little clarification from the more knowledgeable members, especially when we admit that is our case. Be B) .
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • MDawnz1
  • MDawnz1's Avatar
15 Sep 2013 21:40
#606601
There are NO GASKETS between the cases.
Sooo,,,,,
Unless you have a problem down there or just want to spend money and time just leave them alone.
If your point is to get to your pistons,
you don't have to mess with the bottom.
1974 Z1a, still 903
