Clank clank
  • gpzracer
  • gpzracer's Avatar Topic Author
  • ´82 Gpz 1100
Clank clank
14 Sep 2013 15:42
#606416
Hi there a have a´82 1100 am starting hearing a "clank clank" at idle and white smoke what could be?
I guy told me i have to buy a "new" engine its that true? the bike have 15k and was stop for about 10 years. thanks
Ton up or go home.
  • bountyhunter
  • bountyhunter's Avatar
Re: Clank clank
14 Sep 2013 15:59 - 14 Sep 2013 16:00
#606418
Might be the primary chain clacking at idle. Could be the cam chain. Hard to say just guessing.
White smoke is likely valve seals or maybe rings blow by.
Last edit: 14 Sep 2013 16:00 by bountyhunter.
  • Jompa
  • Jompa's Avatar
Re: Clank clank
14 Sep 2013 17:28
#606424
bountyhunter wrote: Might be the primary chain clacking at idle. Could be the cam chain. Hard to say just guessing.
Primary chain on a 82 1100 ?
  • baldy110
  • baldy110's Avatar
Re: Clank clank
14 Sep 2013 20:45
#606439
The 1100, 900 and 1000 cc bikes do not use a primary chains. Unsychronized carbs will make the bike rattle at idle. I have had bikes that after sitting for awhile they smoke on start up. This usually goes away after riding it and getting the engine warmed up. And no you cannot buy a "crate" engine for these bikes.
  • MDawnz1
  • MDawnz1's Avatar
Re: Clank clank
14 Sep 2013 21:05
#606443
"IF" your compression is OK,
it sounds like all you need is a good tuneup and carb synch by someone who knows that kind of bike.
Don't forget an oil and filter change.
Stock air filter?
Make sure it's not damp or dirty.
Last thing, make sure the drain holes in your exhaust are open on stock pipes.
Good Luck with it.
Mike
1974 Z1a, still 903
  • gpzracer
  • ´82 Gpz 1100
Re: Clank clank
15 Sep 2013 17:42
#606554
A have cone k&n filters.The petrol filter was really dirty, i saw bit´s of rust from the tank in the filter, friday toke the tank to sandblast and new plastic cover inside.
Ton up or go home.
