kickstarting my kz750 noise
  • flexvatos
  • flexvatos's Avatar Topic Author
12 Sep 2013 13:50
#606201
i recently got a kz750 twin every time i kick start the bike there's a rattling sound when bike is on neutral when i go to first gear the noise stops and doesn't come back till i put the bike in neutral is this an easy fix or will it be costly im getting a new kick start cover and gasket because its leaking oil from there hopeing its an easy fix :unsure:
  • floivanus
  • floivanus's Avatar
Re: kickstarting my kz750 noise
12 Sep 2013 20:42
#606234
When it rattles is your foot on the kickstart lever still? That sounds like the noise you are describing
Past; 78 kz1000, 83 kz550
Andrew
