Worn Clutch?
  • david-b
  • david-b's Avatar Topic Author
  • I am THAT guy
Worn Clutch?
11 Sep 2013 12:17
#606004
Ended up taking the bike in to a local shop for the front forks (just no time to do myself) and had him check out the carbs and everything while there. Bike now runs like new, and feels totally different. I love it!
So since that's all done, time to move on with the next part. From the other bikes I rode, the clutches has always seemed to have a large friction zone, being able to ease off the clutch and roll/go into gear. It seems like this one is very short, pretty much just engaged and disengaged, which makes it hard starting from a stop. From driving stick most of my life, I know that cars with worn clutches are pretty much like that too, just on and off-type deal.
So the question, with about 28,000 miles, does it sound like the clutch is worn or can it be adjusted to have a little bigger friction zone?
Thanks!
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Worn Clutch?
11 Sep 2013 13:03
#606008
That's the way it is, there is some travel but not much.
Unless the bike has been ridden hard the clutch plates
and steels should be fine.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Worn Clutch?
11 Sep 2013 13:55
#606013
The KZ clutch is really strange and vastly different than any other bike I have owned.
Sounds like you have the same complaints I have.
Welcome to vintage bikes.
Your clutch sounds like its fine to me.
Good riding.
  • david-b
  • I am THAT guy
Re: Worn Clutch?
11 Sep 2013 14:54
#606020
I'm surprised by this.
But it sounds like we're all in the same boat. I may still adjust it to bring the zone a little closer to the handle. Feels like I'm about to fully let go of the clutch when it starts to grab.
Thanks!
/Dave
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Worn Clutch?
11 Sep 2013 19:55 - 11 Sep 2013 19:58
#606067
david-b wrote: I'm surprised by this.
Thanks!
I would follow the manual on adjustment procedure. If it hasnt been adjusted for a long time it wouldnt hurt to readjust it. But your probably not going to gain very much. As already stated these old bikes are diffrent. But after a short period of time, you will get used to it.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 11 Sep 2013 19:58 by Powerstroke_fan.
  • bountyhunter
  • bountyhunter's Avatar
Re: Worn Clutch?
11 Sep 2013 20:21
#606070
Clutch is basically an on/off device. They can be adjusted to make sure they release correctly, but won't change the transition region.
  • MDawnz1
  • MDawnz1's Avatar
Re: Worn Clutch?
14 Sep 2013 03:05
#606380
I have no idea what these guys are talking about.(i do but i wont say)
Just replace your cable with a GOOD brand name one.
Adjust it properly, start from the bottom.
And all will be well.
1974 Z1a, still 903
