Kz110 cylinder head nightmare
  • Bbydylanm
  • Bbydylanm 's Avatar Topic Author
10 Sep 2013 21:24
#605904
So I was replacing my gaskets when I have gone through so much trouble with putting it back together,
Then the unspeakable happened I was adjusting my timing when I noticed a broken valve shim on the ground to find this hole in the cylinder head.
I have tried finding one to buy but it's impossible
Any ideas anyone?
  • Motor Head
  • Motor Head's Avatar
Re: Kz110 cylinder head nightmare
10 Sep 2013 22:07
#605913
Post your year and model, you show KZ110, I assume you mean 1100. Thats a common enough J Head, used thru 81-96. You can find one on Feebay, or PM KZ10006 he might have one. Make sure you buy a good used head, With the correct Camshaft Bearing Caps for that head. As they are machined to fit that head. Watch out for sellers selling a head without Camshaft Bearing Caps.
  • Bbydylanm
10 Sep 2013 22:13
#605916
Oops, it's a 1982 kz1100 spectre d1
I have checked up and down eBay, I guess I will keep my eyes open
  • MFolks
  • MFolks's Avatar
10 Sep 2013 22:14
#605917
  • Motor Head
10 Sep 2013 23:15
#605929
  • Bbydylanm
10 Sep 2013 23:21
#605931
How much will it effect the fact that mine is an 1100?
  • Motor Head
10 Sep 2013 23:25 - 10 Sep 2013 23:27
#605933
The head from the 1000 and the 1100 from 81-83 are the same. The 1100 GPZ is different. The 81-96 1000 police bike is the same, J head.
www.aperaceparts.com/tech/techkz1000.html
Last edit: 10 Sep 2013 23:27 by Motor Head.
