Valve seat repair
10 Sep 2013 17:17 #605874 by freakinbike
Valve seat repair was created by freakinbike
I did a valve job on my gpz750 and one valve still has no clearance. Yes, I went a shim size smaller until i got to the smallest size, still no clearance. Manual says to get the valves cut, which isn't a big deal. The only thing that confuses me is that if I make the valve seat smaller, won't that give me even less clearance? Seems like material needs to be ADDED to the valve seat.
I just need clarification before I take it to the machine shop, thanks
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
  • Z1Driver
  • love the smell of triple smoke
10 Sep 2013 17:30 #605875 by Z1Driver
Replied by Z1Driver on topic Valve seat repair
I'm sure the book is referring to reduce the over all length of the valve. In other words the end of the valve stem gets shaved down.
Blue 1975 Z1B
Red 2009 Concours 14
10 Sep 2013 17:32 #605877 by Cynjut
Replied by Cynjut on topic Valve seat repair
You need to cut the end off the valve. not the seat. I don't remember the exact amount, but you can grind a little bit of the end of the valve stem off.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
10 Sep 2013 18:22 #605883 by freakinbike
Replied by freakinbike on topic Valve seat repair
Cynjut wrote: You need to cut the end off the valve. not the seat.
Well that makes much more sense, thank you
1973 VW Bus
10 Sep 2013 18:25 #605884 by turboking
Replied by turboking on topic Valve seat repair
I'm lucky that my snap-on valve facer has a stemming attachment . :) I can dial in how many thousandths to remove from the valve stem length and it still keeps everything square/flat.....still you can do the same with a cut off wheel or bench grinder and a steady hand......hopefully you will not have to remove much to get in pill range..... :pinch: just remember to check the keepers and cut/grind them accordingly if they protrude above the end of the valve stem or it will unload the retainer and may cause serious engine damage :pinch: best of luck with your repair B)
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
10 Sep 2013 19:46 #605893 by koolaid_kid
Replied by koolaid_kid on topic Valve seat repair
turboking wrote: I'm lucky that my snap-on valve facer has a stemming attachment . :) I can dial in how many thousandths to remove from the valve stem length and it still keeps everything square/flat.....still you can do the same with a cut off wheel or bench grinder and a steady hand......hopefully you will not have to remove much to get in pill range..... :pinch: just remember to check the keepers and cut/grind them accordingly if they protrude above the end of the valve stem or it will unload the retainer and may cause serious engine damage :pinch: best of luck with your repair B)
This is crucial, be sure and follow this advice.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
10 Sep 2013 21:25 #605905 by bountyhunter
Replied by bountyhunter on topic Valve seat repair
The FSM will give you the maximum that can be cut off the end of the valve safely.
