Shaved heads
09 Sep 2013 18:06 - 09 Sep 2013 18:06 #605741 by turboking
Replied by turboking on topic Shaved heads
are we talking using stock pistons? :ohmy: any time you up compression you will get more torque compared to stock....... :dry: more compression = more heat the engine has to get rid of.... and you may need to run higher octane fuel to keep it from detonating, depending on the pistons compression ratio :ohmy: ...... :pinch: unless you dealing with a warped cylinder head ....it's better to go the thinner base gasket route IMO.. no two Kawasaki Z engines were identical as there are production line tolerances built into them + or - .002,.005,.010 etc. setting deck height is done in blueprinting to get the best performance with the combination of parts you have.......IMO :lol:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 09 Sep 2013 18:06 by turboking.
09 Sep 2013 18:50 #605746 by dbc92s10
Replied by dbc92s10 on topic Shaved heads
koolaid_kid wrote:
Nebr_Rex wrote:
4TheKZ1000 wrote:
I had .65 thousand taken off of mine during rebuild to correct a low and high spot.
Damn decimal point. :woohoo:
No doubt. Less than one thousandth. How could they tell it needed it? :huh:
well its obvious you dont know that he put the decimal point in the wrong spot should be .065 or 65 thousands, not less than a thousands :blink: :woohoo: :woohoo: :woohoo:
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
09 Sep 2013 19:51 #605751 by Powerstroke_fan
Replied by Powerstroke_fan on topic Shaved heads
I would not shave the head down and farther than you have to. Theres better ways to get more power than shaving the head down.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
09 Sep 2013 20:03 #605752 by koolaid_kid
Replied by koolaid_kid on topic Shaved heads
No, I was harassing him for putting it in the wrong place, but obviously you don't understand wry humor.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • 4TheKZ1000
  • Visitor
09 Sep 2013 20:22 - 09 Sep 2013 21:18 #605753 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Shaved heads
OK take your shots....I can handle it..... :P
for the record....it was .0065
Attachment pop361x640.jpg not found
Last edit: 09 Sep 2013 21:18 by 4TheKZ1000.
09 Sep 2013 20:54 #605755 by toad
Replied by toad on topic Shaved heads
usually .005-.010 thou will get things true again.Won't notice a difference in power but will keep her from leaking.Safe practice in my opinion...
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
09 Sep 2013 21:29 #605765 by koolaid_kid
Sixty five ten thousandths sounds more like it. Nice pic, btw.
1983 GPz 750
11 Sep 2013 00:48 #605958 by steell
Replied by steell on topic Shaved heads
koolaid_kid wrote: Sixty five ten thousandths sounds more like it. Nice pic, btw.
Didn't you have your 810 milled .025"?
It's 6 and a half thousandths to me :laugh:
11 Sep 2013 02:39 #605970 by koolaid_kid
Ssshhhhh.
1983 GPz 750
