Shaved heads
09 Sep 2013 00:43 #605632 by freakinbike
Shaved heads was created by freakinbike
When shaving the cylinder head, what must be changed along with it? Rejetting, timing, anything like that?
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
09 Sep 2013 01:11 #605637 by 650ed
Replied by 650ed on topic Shaved heads
Depends on how much is shaved, but shave too much and there may be problems with the valves. What is the reason for wanting to shave the head? Ed
09 Sep 2013 01:17 #605640 by Nebr_Rex
Replied by Nebr_Rex on topic Shaved heads
On an overhead cam engine the can timing will retard when the head or deck is milled.
Static compression ratio will increase because of less volume in the combustion
chamber. Cylinder pressure, as checked with a compression gauge, will also increase
because the intake valve closing earlier. And cam overlap, depending on if it is a single
or double overhead cam, to a lesser degree affects cylinder pressure.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: guitargeek
09 Sep 2013 10:43 #605675 by koolaid_kid
Replied by koolaid_kid on topic Shaved heads
You will also have to degree your cams if you do this.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • 4TheKZ1000
  • Visitor
09 Sep 2013 11:21 - 09 Sep 2013 11:28 #605680 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Shaved heads
You can mill the head. We are talking thousands of an inch here ok. The goal is taking off the minim possible and not another thousand.
I had .65 thousand taken off of mine during rebuild to correct a low and high spot.
If you have base damage and need to have a larger amount taken off....you can get oversize gaskets to return you to a proper valve - piston clearance and compression.
DO YOUR HOMEWORK Create a 100% bullet proof plan and follow it to the tee. Find a professional machine shop that wont screw you or your stuff up. Ask tons of questions and ck out their work.
Last edit: 09 Sep 2013 11:28 by 4TheKZ1000.
09 Sep 2013 11:44 #605682 by turboking
Replied by turboking on topic Shaved heads
two ways to get there.....imo....mill head or thinner base gasket, on a Z oem base gasket .020 is stock thickness if memory serves me :pinch: you can buy .005 and .010 (copper)and stack or remove to get your desired height :S or run no base gasket at all...it depends on your cylinder .... :blink: your engine will run better if you can get it a few thousandths down the hole or as close to zero deck as clearances allow ;) :woohoo: re-degreeing the cams and checking valve to valve and valve to piston clearance goes without saying along with maybe a ignition timing adjustment ..... :lol:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
09 Sep 2013 11:53 #605683 by KZB2 650
Replied by KZB2 650 on topic Shaved heads
Had APE cut mine down the min which turned out to be .004 on my KZ650. Cleaned up perfect but probally didn't do much for the compression. Mainly Didn't want to do the slotting of the sprockets and degreeing.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
09 Sep 2013 13:42 #605703 by Nebr_Rex
Damn decimal point. :woohoo:
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
09 Sep 2013 14:59 #605714 by koolaid_kid
No doubt. Less than one thousandth. How could they tell it needed it? :huh:
1983 GPz 750
09 Sep 2013 17:05 #605731 by freakinbike
Replied by freakinbike on topic Shaved heads
650ed wrote: What is the reason for wanting to shave the head? Ed
I'm going to have my head off the block for awhile and was wondering if it would be worth the trouble. They talk about it often on GPZfaq so I got curious.
When taking off the minimum, is there a noticeable power increase, or does the increased compression make it run poorly?
Any references so I can "do my homework" would be much appreciated.
1973 VW Bus
  • 4TheKZ1000
  • Visitor
09 Sep 2013 17:40 #605736 by 4TheKZ1000
you wont notice a thing. Will just help things seal up better is all.
09 Sep 2013 17:47 #605738 by Nebr_Rex
It's all in the math. 750s are 738cc, combustion chamber is around 26cc.
The chamber on the later heads (GPZ) are 65mm necking down to 61mm
in 1/8 in.. You can guesstimate by doing the math. Or you could d'o a search
on the site because it's been talked about before.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
