82 KZ1100 camshaft caps
- yarrg
- dbc92s10
- Thank you received: 5
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
- yarrg
- geerbangr
- Thank you received: 4
1978 KZ 1000
I go by Jason
- Puffin
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
- zed1015
- Thank you received: 1554
There is NO need for another cap.
It is only the joining bridge that is broken not the actual saddle.
Just remove the broken bridge, tidy up the casting and use as two separate caps.( you don't really need to do anything and could just put it back as is )
Make sure you mark them for future reference so they don't get mixed up.
Ideally you would install another dowel on each side but they self align anyhow when tightened and will work just as well as before.
- P21
- Thank you received: 34
zed1015 wrote: This is a common misconception.
i will 2nd that good advise
Kawasaki KZ 1000 Police (2002) P21
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- zed1015
The only reason to replace any would be if it broke across the saddle (not that common actually) or if they got misplaced/lost or damaged in some other critical way and you really need a box full of spare caps to find one close enough to "adjust".
Not just any cap can be made to fit, it all depends on the axis and severity of the misalignment.
I really wish people would realise that a broken bridge is not that serious and despair at the amount of heads that might have been scrapped or broken up needlessly.
- yarrg
- baldy110
- Thank you received: 512
What Zed said. I have done it that way several times, the bridge is not structural. I would cut the remaining bridge off, clean it up and use the caps. Just mark them for the correct position. The KZ650 cam caps are used that way, no bridge.
- yarrg
