- Thank you received: 2
1975 KZ 900 Z1B Engine cover gaskets
- mardimus
Good buy or not a good buy to replace my engine covers?
- MTH76
- Thank you received: 6
They both arrived bent in half and broken.
I would look for a brand name gasket set, his are junk!!!
I have photos to prove it.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
- mardimus
MTH76 wrote: I tried to get a valve cover gasket from him, I tried 2 times.
- moneypit
- Thank you received: 35
www.z1enterprises.com/ShopByCategory.asp...egory=01010104040306
2-76 kz900
St Paul MN
- ezrider714
- Thank you received: 38
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
- mardimus
ezrider714 wrote: I got excellent quality carb bowl gaskets and cam cover gaskets from this seller, this spring. Delivery was very fast. No problems at all, hell his ebay feedback is like 98 per cent, wouldn't be that if you're selling junk :blink:
- ezrider714
Dyna Coils
- mardimus
ezrider714 wrote: Yes I had no problem at all with that seller, also the gasket material is very good quality...
