Valve Adjustment, Intake vs Exhaust
- freakinbike
02 Sep 2013 14:28 - 02 Sep 2013 14:30
I just want to make sure I'm doing this correct before I get too far. On my 1982 GPZ750, I'm doing a valve adjustment. The manual tells me to measure the clearances for two INTAKE valves on timing mark "1 4", either cylinders "#1 and #3, or #2 and #4".
This confuses me, because on timing mark "1 4", I have intake valve #1 completely closed, but intake valve #3 is completely open. (edit: valves #2 and #4 are closed, the lobes pointing to sideways, are those the valves to be measured?) Should I be measuring an open valve? I thought that clearances were checked where the both corresponding valves are closed.
A better question for a newbie, should the cam lobe be pointing up, down, or to the side for when I'm measuring?
Thank you!
Thank you!
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
1973 VW Bus
Last edit: 02 Sep 2013 14:30 by freakinbike. Reason: clarity
- 74ullc
Re: Valve Adjustment, Intake vs Exhaust
02 Sep 2013 15:16
If you do it the way the manual says you have to turn the motor to 4 different positions to measure them all. (I think 4 positions is right) Most people just turn the camshaft until the lobe of the cam is pointed directly away from the valve they want to measure clearance on. When I did mine recently I found I got two different sets of measurements, one when doing it the way the manual states, and one when doing it the other easier way. But the measurements were so close on each method I did that they were basically the same as far as selecting new shim sizes was concerned.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
- Nebr_Rex
02 Sep 2013 15:3374ullc wrote: If you do it the way the manual says you have to turn the motor to 4 different positions to measure them all. (I think 4 positions is right) Most people just turn the camshaft until the lobe of the cam is pointed directly away from the valve they want to measure clearance on. When I did mine recently I found I got two different sets of measurements, one when doing it the way the manual states, and one when doing it the other easier way. But the measurements were so close on each method I did that they were basically the same as far as selecting new shim sizes was concerned.
I've noticed the same thing.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- freakinbike
02 Sep 2013 20:37
Good to know, thank you.
On all four of my intake valves I have zero clearance, but I'm just going off the manual and hope to get my compression back.
1973 VW Bus
1973 VW Bus
- 74ullc
02 Sep 2013 22:12
Yup....definitely need to get the correct clearance on those valves back! Zero = no good.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
1977 KZ1000LTD
1984 VF700F
02 Sep 2013 22:23
Consider this.... The only time a valve is open is when the cam lobe is pressing on the bucket, shim, & valve stem. That is what holds the valve open. So if you try to measure the clearance at that position the clearance will always be zero. If you measure the clearance when the cam lobe is pointing as shown in the manual or pointing directly away from the valve there should be a gap between the cam and the bucket (or shim if your bike has shim over bucket). So that is when you can measure the clearance. Ed
- zed1015
03 Sep 2013 06:46
Just measure with the lobe pointing 180 deg away from the valve.
This is the best way and makes sure you are taking the measurement on the base circle and well away from the ramp.
