MKII Cam and Ignition timing
- hangedk
31 Aug 2013 21:07 - 20 Sep 2013 17:06 #604194
by hangedk
MKII Cam and Ignition timing was created by hangedk
Could anyone here give me specifics about KZ1000 MKII timing? I took my bike to a mechanic but he's never worked on or even heard of the MKII.He gave me a call and told me he just couldn't get it timed right. He's an old guy and a BMW master mechanic, so I know he's not an idiot. Anyway, I'd really appreciate some detailed instructions or scans from a MKII manual on both the cam timing and ignition advance so I can either get that info from him or get the bike back and do it myself. Thanks.
Edit: Thanks for your help, everybody. You've all been awesome as usual. Got everything figured out.
Last edit: 20 Sep 2013 17:06 by hangedk. Reason: update
- 4TheKZ1000
- Visitor
31 Aug 2013 21:51 - 31 Aug 2013 21:54 #604199
by 4TheKZ1000
Replied by 4TheKZ1000 on topic MKII Cam and Ignition timing
No eBay APP ID and/or Cert ID defined in Kunena configurationnot to be a dick.....but buy a factory manual.....it lays out the process in detail. I bought one a read front to back 10 times.
Good luck.
Good luck.
Last edit: 31 Aug 2013 21:54 by 4TheKZ1000.
- hangedk
31 Aug 2013 21:57 #604200
by hangedk
Replied by hangedk on topic MKII Cam and Ignition timing
"Not to be a dick". That's like saying "No offense, but..."
So why bother saying it in the first place? That's a rhetorical question so don't bother. I just ordered one. I was just hoping that someone could help me out on here so that I could speed things along.
- 4TheKZ1000
- Visitor
31 Aug 2013 23:15 #604210
by 4TheKZ1000
- roy-b-boy-b
- Thank you received: 103
01 Sep 2013 09:15 #604271
by roy-b-boy-b
Replied by roy-b-boy-b on topic MKII Cam and Ignition timing
You don't have to time them. The ignition plate is stationary. When you get the manual just follow the procedure for adjusting the timing chain.
It wouldn't hurt to remove the ignition plate and see if the advancer moves freely.
- Thank you received: 2098
01 Sep 2013 09:27 - 01 Sep 2013 09:30 #604274
by Patton
As stated in the FSM (Factory Service Manual), the ignition timing is set by the factory and not intended to be owner-adjustable. The only servicing necessary is lubrication of the advancer weight-arm pivots.
The ignition timing may be "checked" to assure the marks are aligning as they're supposed to.
And operation of the advancer may be verified by viewing it under a strobe-type timing light, watching to see it quickly move backward and forward as rpm is varied by blipping the throttle.
Replied by Patton on topic MKII Cam and Ignition timing
+1roy-b-boy-b wrote: You don't have to time them. The ignition plate is stationary. When you get the manual just follow the procedure for adjusting the timing chain.
Last edit: 01 Sep 2013 09:30 by Patton.
The following user(s) said Thank You: hangedk
01 Sep 2013 09:38 #604279
by Patton
