REAR ROTOR
  • need to know
  • Topic Author
30 Aug 2013 23:53 #604048 by need to know
REAR ROTOR was created by need to know
I have a 1980 KZ 1000 LTD that needs a new rear brake rotor. I need to know what other years and models fit. If you know I would appreciate any help.... Thanks !
30 Aug 2013 23:56 - 31 Aug 2013 02:54 #604051 by BubbaZ1982
Replied by BubbaZ1982 on topic REAR ROTOR
I machined my front rotors due to them being VERY uneven. Kawasaki was nice enough to stamp minumum thickness on them. If this is your case, find a competent machinist.
Last edit: 31 Aug 2013 02:54 by Patton. Reason: delete solicitation
The following user(s) said Thank You: need to know
30 Aug 2013 23:57 #604053 by 650ed
Replied by 650ed on topic REAR ROTOR
According to Kawasaki.com here are the models that use that same rotor. Ed
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
30 Aug 2013 23:59 - 30 Aug 2013 23:59 #604054 by 650ed
Here's a place that specializes in resurfacing bike rotors using specialized equipment. $45 + Shipping. Ed
www.truedisk.net
Last edit: 30 Aug 2013 23:59 by 650ed.
  • need to know
  • Topic Author
02 Sep 2013 16:03 #604497 by need to know
Replied by need to know on topic REAR ROTOR
The one i have is grooved so badly, but I will try to see if I can find the min. thickness #'s.
  • 4TheKZ1000
  • Visitor
02 Sep 2013 16:31 - 02 Sep 2013 16:40 #604501 by 4TheKZ1000
Replied by 4TheKZ1000 on topic REAR ROTOR
be carful buying a new rotor....the b models took the smaller 10-7/8 rear rotor with the 8 rivits on the inner hub not the 9 rivit.
www.cmsnl.com/kawasaki-1980-kz1000-b4-ltd_model15391/partslist/
www.cmsnl.com/kawasaki-1980-kz1000-b4-lt...t/61472.html#results
Attachment bike364-Copy914x852.jpg not found
Last edit: 02 Sep 2013 16:40 by 4TheKZ1000.
  • need to know
  • Topic Author
14 Sep 2013 13:16 #606404 by need to know
Thanks everyone the info helped. my disc was shot... Ordered an EBC Disc. First one from E- Bay # MD4077. Was told it would fit, but used info here and sent it back. Ordered from other company - not on e-bay ( after checking with EBC company ) # MD 4063 was different and EBC says it is correct one!
