- Thank you received: 5
Planning some exhaust changes.
- djturnz
29 Aug 2013 08:14 #603681
by djturnz
1982 KZ750 (4) LTD
Planning some exhaust changes. was created by djturnz
I guess I'm gonna have to look at rejetting. I plan to keep the stock airbox, which I know is sort of unusual. It seems like most threads that come up when I search for info on rejetting, it always involves pods.
I currently have stock style aftermarket mufflers, like what JC Whitney sells. I am planning to switch to a pair of mufflers that have a straight through design with the baffle being around the outside.
With keeping the stock airbox, do I still need to rejet most likely? I'm thinking like the air/fuel mix has already been through the carbs before it reaches the "change".
1982 KZ750 (4) LTD
- Motor Head
- Thank you received: 391
29 Aug 2013 10:25 #603697
by Motor Head
Replied by Motor Head on topic Planning some exhaust changes.
You will probably need to up the main jet a size or possibly two if those are really straight through with little restriction.
Got pictures, or link to the pipes you are looking at?
- djturnz
29 Aug 2013 11:30 - 29 Aug 2013 11:34 #603711
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic Planning some exhaust changes.
They are Cherry Bomb glass packs. 8" body with an overall length of 12". 2in diameter. I will probably either run a large (1/2" or 5/8") bolt across the input opening to add some restriction/ turbulance, or maybe the lolli-pop trick with a washer on a bolt with a wing nut.
This is actual a picture of the 2 1/2" model, but everyone knows what a Cherry Bomb is.
I am going to put these on after the stock "H" pipe.
1982 KZ750 (4) LTD
Last edit: 29 Aug 2013 11:34 by djturnz.
- Grumpy Ole Artist
- Eschew Obfuscation!
- Thank you received: 62
29 Aug 2013 14:42 #603745
by Grumpy Ole Artist
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Replied by Grumpy Ole Artist on topic Planning some exhaust changes.
That is about as "straight through" as they come! Those ought to breathe pretty well...I've never heard glasspacks on an old Kaw...make sure and post some video (at least audio!)You're gonna scare little kids and old ladies! LOL!
1978 KZ650 B2
