Clutch issue caused by me - need help
  • MDawnz1
  • MDawnz1's Avatar
Re: Clutch issue caused by me - need help
30 Aug 2013 18:57
#603977
Is there anyway you can post a picture of what you have now?
It can't hurt and might be very helpful.
Mike
1974 Z1a, still 903
  • 83KZ750LTD
  • 83KZ750LTD's Avatar Topic Author
03 Sep 2013 17:20
#604668
Ok, I got it all figured out this weekend. The issue was a combination of a couple things. First, the clevis on the release shaft was off by 10 degrees. By bottoming out the small pushrod in the release housing and then positioning the clevis on the shaft 80 degrees in relation to the cable bracket, I was able to get full travel in the clutch lever.
The other issue was that there was quite a bit of gas in the oil. As a result, the clutch was a bit swollen and wouldn't disengage very well. I changed the oil and ran it and it worked itself out. I left the tank valve in the on position for a week or so while in storage.
My fuel valve has three positions: reserve, on, and prime. I'm still not sure which position should be used for storage just yet. But, I imagine the carbs may have a float that is sticking. I put a can of seafoam in the current tank of gas in an attempt to clear any gunk out.
Now I have to address the oil seepage issues on the outer cylinders. After my 60 mile ride this weekend, my jeans had a slight brown tint to them.
1983 KZ750-F1 LTD - 8000 miles - 2/2015 - Head gasket time!
  • Motor Head
  • Motor Head's Avatar
03 Sep 2013 21:57
#604712
"Prime" is to be used for starting the bike after it has set for a couple of weeks or more. "On" is only actually on when the motor is running, as there is a vacuum diaphragm which shuts the fuel off when the engine is of. "Res" is the same, but has a much lower pick up point in the tank, for when your getting low on fuel.
So if your crankcase has/ had Gas in it, the Petcock would need a rebuild kit. There is a few parts that will come in the kit, which should take care of the issue.
