- Thank you received: 1
Clutch issue caused by me - need help
- 83KZ750LTD
I've been trying to complete the installation of new handlebars and in the process, my clutch cable split. So, I decided to replace the clutch cable as well.
Getting the old cable off was tough because I couldn't get the ball end off of the clevis down at the clutch release shaft. I actually ended up removing the clevis so that I could get to the cable end. In doing so, I believe I messed up some kind of preload on the shaft.
Now that I have the new cable attached at both ends, there is very little resistance in the clutch lever and the clutch doesn't disengage.
I've referred to manuals and it keeps mentioning a clutch adjustment screw but I can't find where that is on the bike. I have a shaft drive model and I'm thinking that the manual references chain drives specifically.
How do I get resistance back in the clutch lever and bring the clutch back to a disengaged state?
1983 KZ750-F1 LTD - 8000 miles - 2/2015 - Head gasket time!
- 83KZ750LTD
- Thank you received: 2829
- 83KZ750LTD
Attachment 00001_2013-08-28-3.jpg not found
- MDawnz1
- Thank you received: 27
Do you have that little rectangular cover on what would be your sprocket cover?
Held on by 2 screws?
If you do, look under there.
Sorry, I can't even find a decent picture of a 83kz750ltd to blow up.
1974 Z1a, still 903
MDawnz1 wrote: Just a shot in the dark.
The F1 has a different setup. Here's what the sprocket cover looks like. It doesn't have that little access cover that so many other models have. Ed
Attachment 00001_2013-08-29.jpg not found
- 83KZ750LTD
I've tried to place the clevis at diffent points on the splined shaft to see if I could get a different result but haven't had any luck.
Before the old cable split, the clutch worked perfectly. The only thing I changed was the cable and I removed the clevis from the release shaft.
- MDawnz1
You seem to have all the exploded drawings,
can you help us PLEASE with one of the clutch actuator?
Thanks
Mike
1974 Z1a, still 903
Go to Kawasaki.com. On left side put cursor over "Owner Information" then on drop down menu click on "Parts Diagrams." The click "Continue" next to "Motorcycles" and click on model/year/etc. on drop down. Once you get the list of parts for your bike you can click on the category of parts - such as "Air Cleaner" and you will see a diagram of all the parts for that category. Then when you click on an actual part number on the list under the diagram it will say if the Item Status is "Active." If it is “Active” Kawasaki still sells the part through dealers. Also, at that little page you can click on the yellow highlighted question mark for a cross reference of which bikes share that part or click on the red highlighted S to see earlier part numbers for the same part.
If you want to change bike models you can enter the new model at the top. Also, you can put in just the first part of the mode (i.e. KZ750) and it will list all the years and sub models. You also can put in a part number up top and switch the word “MODEL” to “PART NUMBER” using the little drop down in that box. If you do that it will show all the models that part is used on.
Attachment 00001_2013-08-30.jpg not found
- Motor Head
- Thank you received: 391
83KZ750LTD wrote: As 650ED just mentioned, the F1 is a bit different. There isn't a window in the cover and there doesn't appear to be anything underneath it that is easily accessible as well.
I believe this is what your problem would be, this needs to be located on the splines in the correct spot. Is there a reference mark on the Top of the Shaft above the splines?
Also the cable will have an adjustment at mid point in the cable, to take out additional slack, before you adjust at the lever.
- 83KZ750LTD
It seems like the longer pushrod is stuck. I can't push it in or pull it out.
I'm waiting on a service manual but I might open up the clutch cover tonight or tomorrow to see where everything is hung up. This is my first time working with a motorcycle clutch so I'll be taking a lot of pictures.
