30 mm. Shims? What bike uses those?
- bluezbike
25 Aug 2013 19:15
I have somehow ended up with 8 shims that measure 30 mm diameter...any idea what motor those fit. I know my KZ 1000 uses 29 mm diameter and the 750 twins use 32 mm.
79 KZ 1000 LTD
- dbc92s10
Re: 30 mm. Shims? What bike uses those?
25 Aug 2013 20:37 - 25 Aug 2013 20:44
i believe those are suzuki gs1100 shims i know they are suzuki just not sure on which model pm crh he will know for sure
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
Last edit: 25 Aug 2013 20:44 by dbc92s10. Reason: adding tex
- DFIGPZ
25 Aug 2013 21:39
Suzuki GS1000 GS1100 is rocker arms.
1984 750 Turbo
- Dr. Gamma
25 Aug 2013 21:56 - 25 Aug 2013 22:16
The GS1000 2 valve motor use a 29.5mm shim.
Most of the early Suzuki 2 valve motors use that 29.5mm shim if it is a shim type motor.
Sure they are not 29.5mm?? Never saw any motorcycle I know of use a 30mm shim!!!
1986 RG500G 2 stroke terror.
Last edit: 25 Aug 2013 22:16 by Dr. Gamma.
The following user(s) said Thank You: bluezbike
- bluezbike
26 Aug 2013 00:27
Double checked with a vernier caliper....29.5 mm it is, thank you Dr. G
79 KZ 1000 LTD
