cylinder head
- brianrae33
cylinder head
24 Aug 2013 18:52
Wondering if anyone has a cylinder head for an 82 kz1000 for sale??? been dealing with the camshaft cap bolt holes and they are shot...had the timeserted and they must have used the wrong size bit because even they failed...was thinking of trying to find a machine shop to fill the holes back in and redrill and tap...
1982 kz1000ltd
- Powerstroke_fan
Re: cylinder head
24 Aug 2013 20:25
You can use a little bigger bolt. Also if iam not mistaken ive seen people put longer bolts in also.
1977 KZ 1000 work in progress
- brianrae33
Re: cylinder head
25 Aug 2013 12:37
it's already bored as big is it can be taken..either have to find somewhere that can fill the holes in and redrill and tap them or...find another head...nothing worth looking at on ebay currently..
1982 kz1000ltd
- daveo
Re: cylinder head
25 Aug 2013 13:02
Would the (Time Sert) Big-Sert work?
I used that kit to redo the four cam-end 6mm holes on a head I had, and they worked beautifully.
1982 KZ1100-A2/1170 sleeper 😀
- dbc92s10
Re: cylinder head
25 Aug 2013 13:34
Pm wireman I know he's got a couple j model heads :pinch:
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
- Powerstroke_fan
Re: cylinder head
26 Aug 2013 08:22
You cant use a longer bolt? Iam pretty sure ive seen people put longer bolts in them.
- MDawnz1
Re: cylinder head
29 Aug 2013 03:21
Can I ask nicely what started all this with your cam cap bolts?
1974 Z1a, still 903
- daveo
Re: cylinder head
29 Aug 2013 05:44
brianrae33
What is the current hole diameter where the Timeserts failed? Did they pull out, or spin in-place?
- brianrae33
Re: cylinder head
31 Aug 2013 12:26
pulled out...intake side is nice and tight...but 5 of the 8 on the exhaust side failed...i'm at a loss..
1982 kz1000ltd
Re: cylinder head
31 Aug 2013 12:34
Joe at Pitstop before anything else happens
