cleaning the engine
  • crusierlover
  • crusierlover's Avatar Topic Author
cleaning the engine
23 Aug 2013 05:29
#602748
I bought the 79 kz 1000 motor a few days ago.I dont thing it has been in a bike for several years.once I know the motor runs and is ok, I will clean it.It has lots of oxidization.I have seen thes cases and covers polished to near mirror like finish and was wondering what do you use to polish up your engine?
Proud owner of 1982 650csr again soon. keeping it this time
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: cleaning the engine
23 Aug 2013 09:51
#602759
1982 KZ1100-A2/1170 sleeper 😀
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
24 Aug 2013 07:07 - 24 Aug 2013 07:16
#602855
OMR (old man rock} has plenty of post on cleaning engines. I use a die grinder and a wire wheel for heavy cleaning. A regular drill will work. For a finish shine I use clay bars and my die grinder if the parts are on the bike and a large buffer if the parts are off the bike.
Here is a link to OMR"S clean engine.
www.kzrider.com/media/kunena/attachments/11624/SimpleGreen.JPG
Last edit: 24 Aug 2013 07:16 by roy-b-boy-b.
  • crusierlover
25 Aug 2013 01:56
#602948
Thank you.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
25 Aug 2013 09:10
#602968
You can also use sandpaper or sandpaper on a power tool. I started out with a ruffer grit then worked my way up to 1000 grit. Then i wet sanded it with wd-40. Then i buffed it with some harbor frieght buffing wheels on a cheap drill. Then i started out with some white diamond metal polish. Its has a little grit in it, so it helps get it to a mirror finish. Then i went back over it with mothers on another buffing wheel. The mothers really makes the engine shine.
1977 KZ 1000 work in progress
  • crusierlover
25 Aug 2013 11:14
#602989
Thanks powerstroke.Yep, i can see a few days doing this.
  • Shdwdrgn
  • Shdwdrgn's Avatar
27 Aug 2013 15:35
#603352
Hey I've been wondering about the SimpleGreen method... Do you guys dilute it with water as per the label, or do you soak with higher/lower concentrations? Any issues with dropping the carbs straight into a bucket of the stuff, or should I pull out any of the seals first?
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
  • roy-b-boy-b
31 Aug 2013 12:37
#604137
Bump.
  • Old Man Rock
  • Old Man Rock's Avatar
01 Sep 2013 10:06
#604284
Nope straight out of the spray bottle.... ;)
SG is pretty safe regarding the chemicals... I actually use it as a hand cleaner, removes the oil & grime...
If carbon build ups as in the piston dome images, lets soak over night and use a tooth brush/nylon brush to clean.... Seriously, all I did on those 30 year old pistons...
Oxidized engine cases, spray down and let soak in.... Repeat every so often then hit with Orange nylon brush on a drill.... Hose off & dry, then final spray with clean tooth brush for a little shine...
For higher shine, use a soft wire brush on a drill, light touch = little pressure and she'll shine right up... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
01 Sep 2013 10:13
#604285
Recent Voyager Xii build.... PO was douche nipple & totally neglected her so used about a Gallon on her, she all purdy now.... B)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
01 Sep 2013 10:19
#604287
Looks great!! Man, that previous owner took a lot a pride in his ride, didn't he? :blink: :blink:
Attachment 00001_2013-09-01.jpg not found
  • Shdwdrgn
  • Shdwdrgn's Avatar
01 Sep 2013 13:39
#604305
Any suggestions on what I could soak a case in to remove the original paint? Got a replacement from a police bike -- I wanted the black color, but this paint is peeling & cracking everywhere, so I think I'll be better off stripping it and starting from scratch. Anyone had good success just soaking in regular paint thinner, or is there something that would work better?
1981 KZ1000-JK1
