engine condition - good, bad, can be lived with?
- patrickpe
18 Aug 2013 01:01 - 18 Aug 2013 01:05
bike: 1983 kz550c4 ltd
what constitutes a "good/acceptable" or "better replace that" cylinder/crankshaft section?
after having a hard time starting the bike & having it make a rather loud clacking noise from the left side last week i figured it was a good time to pull the carbs & have a look at them - and i found 2 of the 4 slide flappers were missing (2 and 3) but #2 appears to have recently been sucked into the engine. figuring that since the carbs were off this would also be a good time to check the engine out & replace the gaskets i've taken off the cylinder head, camshafts, & cylinder/valve section down to the crankcase top.
in the 1st pic you can see the 2 pieces of the carb slide flapper i found in #2 (#1 is on the left) & what the bottom of the valve end looks like - one piece is actually stuck in there, the longer piece on the right side can simply be removed.
right side seems "ok", though carbonated(?).
what i'm wondering is whether or not i should find some parts in better condition & replace what i have or would cleaning up what i have be sufficient to get another 5 or 10k before replacing the crankcase, cylinder section, or camshaft section (camshafts appear visibly ok). or none of the above & some other approach?
picture 2 is the crankcase top (#1 on left)
picture 3 is right side, cylinder bottom end
picture 4 is what it used to look light at night before i took the carbs out & most of the engine.
regards,
Attachment ScreenShot2013-08-17at3.00.25PM.JPG not found
Attachment ScreenShot2013-08-17at2.59.35PM.JPG not found
Attachment 20130817_kz550_cylinderbottomright_4053web.jpg not found
Attachment kz550-night.jpg not found
regards,
Last edit: 18 Aug 2013 01:05 by patrickpe.
- Spectre1982
Re: engine condition - good, bad, can be lived with?
18 Aug 2013 01:54 - 18 Aug 2013 02:16
To test the valves you can put the spark plugs in the head, flip it over and fill the chambers with gas or solvent. If it leaks out then the valves aren't sealing fully. I'd take the valve train apart, inspect everything and replace the valve guide seals even if it's not leaking.
I usually do a compression test to check the state of the motor before taking it apart, but you're already past that. You might consider taking the cylinders off so you can measure the cylinder diameter, connecting rods, pistons, etc. You need a t-gauge and micrometer set. It cost me about $80 for a pretty complete set. There is a whole engine maintenance section on how and what to measure in the service manual. It covers every nut and bolt.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
Last edit: 18 Aug 2013 02:16 by Spectre1982.
The following user(s) said Thank You: patrickpe
- car5car
- Banned
18 Aug 2013 03:48
Take apart, clean combustion chambers by drill and wire brush, remove pieces. Lap valves to see how good/bad valves and valve seats are.
If piece is under valve, valve is possibly bent. Good head is probably dirt cheap on ebay.
96 Yamaha Royal Star
82 Yamaha Virago 920
- Powerstroke_fan
18 Aug 2013 09:24 - 18 Aug 2013 09:25
You can fill the intake and exhaust runners with gas to see if they leak. But by the way it looks they probably will. If it was me i would pull the valves being careful to keep each valve in its original location. I do the same with the buckets and springs and keepers, i know those could be moved, but i like them to go right back where they came from. Also did you check your valve clearance before disasembly? It would make it easier knowing what you needed and where. Also did you mark which shim sizes go where? If you do end up getting a new head or valve job it will change, but if you just clean it up and lap the valves and it might be ok.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 18 Aug 2013 09:25 by Powerstroke_fan.
- patrickpe
22 Aug 2013 00:33
thanks for the responses. i've been a little busy this & week & am trying to make time to get the valves out. hopefully i can squeeze that in tomorrow to see what state they're in. i've looked on ebay for a new valve section & am a bit surprised to not see a lot of them, and what is listed tends to be of the rust bucket variety. hopefully there won't be too much, if any, valve damage. now if i can just get those carburetor throttle arm screws out without damaging them ... those are in tight.
- MDawnz1
22 Aug 2013 22:08
OK ,let me see if I have this right.
Your 83 kz550 ate 2 of your carb butterflies?
Plus the 4 screws that hold them to the shaft?
Or did the screws just snap the heads off? A big sneeze or a backfire or something that you remember?
WOW !!
and
OUCH !!
WOW !!
and
OUCH !!
1974 Z1a, still 903
