- Thank you received: 8
kz1000 motor fits funny
- chonus
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
- wireman
- Thank you received: 299
- rixtrix
- Ride on !
- Thank you received: 5
1982 GPz1100
- chonus
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- rixtrix
- Ride on !
I assume they are similar(if not the same) as my gpz- a steel sleeve with rubber molded to the outside. The caps could have squished the rubber to one side if the motor mounts were not snugged correctly at some time and allowed the engine to "twist" in the frame. I know years ago tollerances aren't what they are now and I had to put washers in between the frame and motor to get rid of gaps similar to that.chonus wrote: I didnt try tightening to see if it pulls in, i feel like it would just bend the other side in before it closed that gap. Do those motor mount "caps", if you will, crush? I havn't looked at them very thoroughly, but they dont look squashed. and I thought they were just rubberized steel spacers anyway
1982 GPz1100
- chonus
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- chonus
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- guitargeek
- Thank you received: 50
I ran into the same thing on Ponch. The U-shaped spacer fits that gap, specifically.chonus wrote: well, im still having the same problem. I have another frame (02 kzp) and I got new dampener caps, and I have the same gap issue. the book doesnt mention a spacer, but when I look on bike bandit, it appears there is a u-shaped spacer part no 92022a anyone have any thoughts? www.bikebandit.com/houseofmotorcycles/19...m/o/m150522#sch85524
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
