Secondary air injection system.
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
17 Aug 2013 21:37
#601905
I just found out that vacuum valve on top of engine is letting air in exhaust system, not inside engine block.
Is there system letting air in engine block?
PCV system?
96 Yamaha Royal Star
82 Yamaha Virago 920
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Secondary air injection system.
17 Aug 2013 22:07
#601909
Well, it should have a breather tube to let out any blowby. Not sure if it has a valve or not, neither my KZ nor my GPz had one, but they did have baffling to prevent oil splashing out.
Not sure what you are referring to AFA you exhaust, though.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • loudhvx
  • loudhvx's Avatar
17 Aug 2013 22:36
#601912
You can just block off the ports on the top of thevalve cover, or just connect a hose from one to the other.
Then block off the small vacuum lines going to that vacuum diaphragm.
The following user(s) said Thank You: car5car
