1981 KZ750 LTD Engine Replacement/Swap
17 Aug 2013 12:07 #601837 by afotion
Hey Guys,
So As some may know I managed to blow my motor last week.
I would like to know which engine I can drop in place that will fit this bike with not many headaches.
Or if anyone has a 750 motor for sale :laugh: :woohoo:
81' KZ750 LTD
17 Aug 2013 14:14 #601851 by koolaid_kid
Replied by koolaid_kid on topic 1981 KZ750 LTD Engine Replacement/Swap
IIRC that engine was made from 1980 to 1985. In cruiser, standard and sport models, with various styling, such as Spectre, GPz, LTD, etc. I would think any 750 chain drive in that series would fit into your frame.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
17 Aug 2013 15:30 - 17 Aug 2013 15:37 #601854 by martin_csr
Replied by martin_csr on topic 1981 KZ750 LTD Engine Replacement/Swap
Any KZ700/750-4 chain drive, most likely.
Other possibilities. ZR750 -->> ~91-93 Zephyr & ~2000-2002 ZR7/ZR7S (air cooled models).
Last edit: 17 Aug 2013 15:37 by martin_csr.
17 Aug 2013 16:18 #601860 by afotion
Replied by afotion on topic 1981 KZ750 LTD Engine Replacement/Swap
Which one has the most horses? Also if I look at Engines outside of my model what kind of changes am I looking at to make a different engine work?
81' KZ750 LTD
17 Aug 2013 17:19 - 18 Aug 2013 11:29 #601870 by martin_csr
I'm pretty sure the 80-83 750E Standard & 750H Ltd will be an exact fit. Any fitment problems with the other chain drive models would be in regards to the engine mounting points. The 83 GPz might be different, since I don't think it uses the same engine guards (which probably indicates different mounting points???).
As for horsepower, it seems like a ZR750 would be higher, but I checked one time & the ZRs are in the 75-78 range which is about the same as the KZ750. The ZR750 engine is based on the KZ750. The ignition system is probably different, but I'd guess that wouldn't be a problem. I mentioned the ZR because I'd like someone to try it, to confirm whether or not it can be done & how easy it will be.
Last edit: 18 Aug 2013 11:29 by martin_csr.
17 Aug 2013 17:25 - 17 Aug 2013 17:26 #601871 by koolaid_kid
I checked the various years and it seems the horsepower of all the 2 valve 750-4 engines remained pretty much constant. Not sure on the mounting of the engine of GPz vs. KZ, but the 83-85 GPz had the highest horsepower rating.
Really, though, if you want more power get a KZ1000 and be done with it. While I really prefer my GPz over my 81 KZ750E, neither comes close to the power of my 83 GS1100E. No replacement for cubic centimeters. :)
Not sure where you are located, but there is an engine/frame for sale in Illinois, just north of Chicago, in the For Sale section of this forum.
1983 GPz 750
Last edit: 17 Aug 2013 17:26 by koolaid_kid.
17 Aug 2013 17:32 - 18 Aug 2013 11:36 #601874 by martin_csr
True. But it may be cheaper to replace the engine than to buy a new bike. Plus, he'd be keeping one on the road.
There's a 750 engine listed for sale here on KZR. The VIN lookup a Kawasaki.com indicates that it is 82 KZ750-H3.
edit: frame reported sold; not sure about the engine which is missing the valve cover; if it is available, I would get more info about it... who knows what's wrong w it???
Last edit: 18 Aug 2013 11:36 by martin_csr.
17 Aug 2013 17:36 #601876 by koolaid_kid
martin_csr wrote: True. But it may be cheaper to replace the engine than to buy a new bike. Plus, he'd be keeping one on the road.
He just reported it sold.
1983 GPz 750
17 Aug 2013 21:32 #601904 by car5car
Replied by car5car on topic 1981 KZ750 LTD Engine Replacement/Swap
What is wrong with your motor?
Knocking, smoking, seized?
96 Yamaha Royal Star
82 Yamaha Virago 920
10 Mar 2017 23:03 #756396 by Thorsdotter
Replied by Thorsdotter on topic 1981 KZ750 LTD Engine Replacement/Swap
Sorry to hear about your motor. Mine blew at the end of last summer and ive spent all winter working to rebuild it. Some parts are pretty easy to find and affordable on a budget, while some are really hard to find if at all. Just thought id throw that out there if you were thinking of rebuilding. Good luck.
11 Mar 2017 07:57 #756414 by riturbo
Replied by riturbo on topic 1981 KZ750 LTD Engine Replacement/Swap
I know wheres theres a few gpz 750 motors . Two of my friends have extra motors . One in new hampshire has a bottom end and one in R.I who has one complete . Pretty sure they would bolt right in .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
11 Mar 2017 08:25 #756417 by riturbo
Ha HA just realised this is a three year old thread .
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
