DYNA S ignition ****help***
  • homert1
  • homert1's Avatar Topic Author
15 Aug 2013 09:10
#601535
Gentlemen.......I need assistance. I have recently purchased a DYNA S ignition for my 76 KZ900....(new coils/wires etc).installed in the bike and fired up immediately. THe bike ran awesome for a few weeks. After some time I lost spark on 2-3 cylinders!!!? After tracing my steps......checked and double checked, I determined the DYNA S to be the problem. I returned it to DYNATECH to be checked and they returned it saying there was nothing wrong with the module. I reinstalled the unit, double checked all connections, and still no spark on 2-3 cyls??? Am I missing something?? Any suggestions???
  • Motor Head
  • Motor Head's Avatar
Re: DYNA S ignition ****help***
15 Aug 2013 09:37 - 15 Aug 2013 09:47
#601537
Here is the link to their trouble shooting page. www.powercommander.com/downloads/Support...Manuals/DynaSTSG.pdf
I would have all 4 plugs out, then swap the primary coil wiring to see if the same side is dead or if it switches to 1-4. If it switches to 1-4, and the 2-3 now sparks, check for voltage at the offending side on the coil. Check the signal side for continuity from the Dyna S to the Coil,if all good then I'd say Bad Dyna S.
Last edit: 15 Aug 2013 09:47 by Motor Head.
  • homert1
15 Aug 2013 09:47
#601539
Thankyou for the link.........as you suggested.....I did this test initially and determined it was the bad module.......so I returned it to DYNATECH. They returned the module and indicated NO issues with the module but the problem remains??? That is why I'm so confused
  • loudhvx
  • loudhvx's Avatar
15 Aug 2013 11:47 - 15 Aug 2013 11:48
#601559
Swap small wires from 1-4 coil to the 2-3 coil. If 2-3 does not spark, then the 2-3 coil is bad.
(The motor will not run, wired this way, but you can check for spark.)
Last edit: 15 Aug 2013 11:48 by loudhvx.
  • homert1
15 Aug 2013 12:10
#601561
Thanks........purhcased new coils at same time I bought the ignition.....and I don't think they are the issue as I am not getting a signal from the Dyna module when I try to set the timing ( as instructed by Dynatech ) for 2-3 cyls!!? Next test is to check distance on 2-3 pickup on module to see how far ( if possible ) the module is away from the sensor? Dynatech claims any further than .040" and the unit will not pickup any signal.......it's worth a shot
Thanks for the help
  • bountyhunter
  • bountyhunter's Avatar
15 Aug 2013 16:00 - 15 Aug 2013 16:09
#601578
Wonder if you have a bad wire or connector in the circuitry going to the hall effect sensors.
Last edit: 15 Aug 2013 16:09 by bountyhunter.
  • homert1
15 Aug 2013 16:42
#601580
I had the unit checked by Dynatech and they say no issue with the unit or wiring harness.
When I get time I'm going to check all connections again.
  • Old Man Rock
  • Old Man Rock's Avatar
15 Aug 2013 19:18
#601601
Verify coil signal or power is not touching/arching to the frame on the mounts....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • homert1
16 Aug 2013 09:18
#601662
OMR.......thanks. I am going to take the weekend and check all connections. Connections....coils.......grounds etc and see if I can get this thing corrected. I appreciate the help. Hopefully I can get this ironed out before the snow flies!!!.......being in Canada and all!!!EH
  • Motor Head
16 Aug 2013 09:53
#601667
Old Man Rock wrote: Verify coil signal or power is not touching/arching to the frame on the mounts....
While the mounting is an issue with these Dyna coils, I see most have been blowing a fuse when it is shorting.
There are posts where the cure has been a Nylon Spacer in place of the Metal spacer for the screw/ bolt on the end of the coil with the terminals. Ace Hardware store has a selection.
  • homert1
16 Aug 2013 11:41
#601683
Thanks Motor Head..........that is another place I can check. Running out of options!!!
  • Old Man Rock
16 Aug 2013 14:03
#601707
"lost spark on 2-3 cylinders!"..... Blown Fuse on 2/3 only... :S
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
