1000 gasket on 900
- auggiedog
1000 gasket on 900
11 Aug 2013 12:18
all, have been gone for a while, but am finishing up my 1015 bored 900, and I have a question.
Has anyone use 1000 one piece gaskets on a bored 900 with the center groove for the rubber? Reason I ask is Redline in Skokie builds all their bored 900's with the one piece by adding a bead of red rtv in the groove....any thoughts here? They say better as sometimes, the ring will shift in assembly, or something like that.
Thanks!
K
BTW, went to Advance Sleeve in ohio for the most recent work, fresh bore on another set of 900 jugs, decked and new rings gapped for my wiseco pistons, they did perfect work....rocked...
Thanks!
K
- turboking
Re: 1000 gasket on 900
11 Aug 2013 12:22
yes to your question... and i have used both rtv and epoxy to fill center o ring groove...worked :lol:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- Powerstroke_fan
11 Aug 2013 13:41 - 11 Aug 2013 13:43
i use rtv to fill the groove on mine with no problems. If you need anymore work done in ohio i would john pearson from pearson racing a call. He treated me extremely well on everything ive ever took to him. His only downfall is hes a one man crew so hes pretty busy. But the work he does makes up for the time. Hes in west alexandria ohio. He does it all, welds and balances cranks, back cut trans, jug work and occasionally head work also.
1977 KZ 1000 work in progress
Last edit: 11 Aug 2013 13:43 by Powerstroke_fan.
- auggiedog
15 Aug 2013 21:03
epoxy! good idea....I sometimes am a little heavy on the rtv.....
Thanks!
Thanks!
- auggiedog
15 Aug 2013 21:04
Thaks! good to know of yet another resource....im in Chicago but advance sleeve was highly recommended...after talking to them a bit I realized they are owned by Cometic, the gasket co...
