- Thank you received: 83
kz 1000 Cylinder head temps???
- Powerstroke_fan
11 Aug 2013 10:08 - 11 Aug 2013 10:15 #600812
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
kz 1000 Cylinder head temps??? was created by Powerstroke_fan
So i finally got a temperature gauge for my bike. It is just a tto gauge. You take off your crush washer on your spark plug and it goes on there. So its really only telling head temperature. Anyway the question is, Whats the hottest These motors should handle before i start shutting it down? The hottest it got was around 410. But mainly likes to stay around 350 to 380.but when you come up to a stop sign or putt around real slow it will heat up. I know there air cooled motors and i dont allow it to sit and idle, just at stop lights only and i dont like doing that very much on really hot days.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 11 Aug 2013 10:15 by Powerstroke_fan.
- les holt
- Thank you received: 288
11 Aug 2013 10:54 #600822
by les holt
Replied by les holt on topic kz 1000 Cylinder head temps???
We used the same type of temp gauge on flat head briggs when we raced. most builders liked 375 max I preferred 405-410, it produced more power but, you didn't have time to tweak the carb if it started making more heat where as 375 you did.
I'd say your fine.
Les
I'd say your fine.
Les
- zed1015
- Thank you received: 1554
11 Aug 2013 11:04 - 11 Aug 2013 11:44 #600825
by zed1015
Replied by zed1015 on topic kz 1000 Cylinder head temps???
You've just added one more thing to worry about, distract your attention from the road and more weight too.
I've screwed the nuts off these motors and had them stinking hot with no issues.
Take it off and just RIDE, unless of course you want to observe what temp the motor was when you ran into the back of that truck :ohmy: .
Last edit: 11 Aug 2013 11:44 by zed1015.
The following user(s) said Thank You: turboking
- Powerstroke_fan
11 Aug 2013 13:33 - 11 Aug 2013 13:35 #600841
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Replied by Powerstroke_fan on topic kz 1000 Cylinder head temps???
Ya i dont really watch it very often. I just wanted to be able to see how hot it was while sitting in traffic. I also wanted to be able to see if it gets to hot and i need to shut it down. I just got alot of money in this bike now, so i gotta have some form of insurance lol. So whats the max i should let it get then? As i took it les said 410 is ok. Iam not really worried about it overheating when riding normal. I wouldnt worry about it if it wasnt such a big motor.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 11 Aug 2013 13:35 by Powerstroke_fan.
