gpz550 clutch questions if you have a gpz550 read
- fallout3
gone to put it back together an noticed a ball bearing sat on the floor next to the clutch case that i removed and i was like "has that come from the bike" i worked on a few kwakers and never had a ball bearing it may not be from the bike but i wanted to just clarify that with some other people first before i put it back together if enything it could go on the center hole between the clutch shaft and the pin? maybe? let me know asap guys and i was wondering why someone hasnt uploaded a copy of the manual on here save us all some money just a thought
81-83 gpz550 and 83-85 zr400f
- boatdrinks
- Thank you received: 54
www.nwsca.com/gpz550/garage.htm
Be aware that the GPz clutch does not adjust the same way as all the other KZ clutches so please read the adjustment procedure before proceeding to adjust the clutch.
Good luck!
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
- Thank you received: 2829
fallout3 wrote: my clutch was stuck the bike had been sat for ten years so you can imagine it was stuck so ive taken it all apart cleaned it ruffed up the friction plates an cleaned all the old gripe of the metal plates
It would really help if you would add your bike's year & model to your signature line; these bike's have a lot of different parts.
If your GpZ550 is a 1981-1983 (that would be a KZ550-D1, KZ550-H1, or KZ550-H2) the ball bearing (if it is an individual steel ball) fell out of your clutch. It should be between the clutch push rod and the clutch spring plate pusher (see first picture) and will need to be installed of the clutch won't operate.
If your GpZ550 is a 1984-1986 (that would be a ZX550-A1, ZX550-A2, or ZX550-A3) that individual ball would not belong in there as Kawasaki replaced it with a ball bearing consisting of several balls and their races (see second picture). Ed
Attachment 00000_2013-08-09.jpg not found
Attachment 00003_2013-08-09.jpg not found
- loudhvx
- Thank you received: 1616
There are two types of KZ550 clutch actuators. They adjust opposite of each other. My signature has details for the ball-pocket type, which in on the 81 to 83 Gpz550's.
The push-rod's ball bearing can't come out on the sprocket side, but it can fall out on the clutch side. And as Ed said, it's only on the 81 to 83 Gpz550's.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- fallout3
