Is it better to tighten Headbolts with Hot Engine
- swaluda
09 Aug 2013 13:46 #600593
by swaluda
Is it better to tighten Headbolts with Hot Engine was created by swaluda
Or does it not make a difference if engine is cold? Thanks Stan
- Roadflyer
- Thank you received: 13
09 Aug 2013 13:58 #600594
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Replied by Roadflyer on topic Is it better to tighten Headbolts with Hot Engine
torque them down when it is dead cold.
The following user(s) said Thank You: Del_Herring
- Del_Herring
- Thank you received: 29
09 Aug 2013 14:17 #600596
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Is it better to tighten Headbolts with Hot Engine
Definitely torque while cold. This is how engines are assembled initially, and that's what the specs are made for. Stuff is different sizes when warm. If you torque while hot, you're liable to have things either loosen up as the engine heat cycles through use, or to simply break something.
- MFolks
- Thank you received: 540
09 Aug 2013 14:45 #600599
by MFolks
Replied by MFolks on topic Is it better to tighten Headbolts with Hot Engine
Same thing applies when checking oil levels, and tire pressure, always check when cold.
