- Thank you received: 83
valve clearance too tight
- Powerstroke_fan
angryeric116 wrote: Could you take the shim out of the bucket, measure the clearance, and get a shim to fit? I am having the same problem as the OP right now.
Ive never heard of anyone managing that. I would either drop shim size as already mentioned or a general rule of thumb. If you can not fit a guage under it but can spin the bucket with your thumb. Try droping one size and remeasure. If you cant fit the guage in and CANNOT spin the bucket with your thumb,drop two sizes and remeasure. Do you guys have a shim tool?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- Motor Head
- Thank you received: 391
Well your bike doesn't use it because of the shims being Under Bucket. But the 900/ 1000 have shims on top,so there is a tool for helping with extraction. It holds the Valve and spring down, so there is a gap under the cam to remove the shim. Factory tool being different than the Aftermarket.koolaid_kid wrote: I have to ask, what is a shim tool?
- Thank you received: 2098
The batwing may be used without the lever part.
factory
factory copy
batwing
- koolaid_kid
Patton, would this be the one?
1983 GPz 750
- angryeric116
I'll keep you guys updated. Two of the clearances are I already checked and i was able to fit a .508mm and .3XXmm feeler gauges in there. So happy to be making progress on this project.
1979 KZ 1000 LTD B3
in the process of restoring.
Weisco 1 to 10.25 pistons
unknown 4 into 1 , pod filters, #122.5 main jets, #15? Idle jets
When properly positioned, the batwing will prevent the bucket from rising when the cam lobe is moved away from the shim that's situated on top of the bucket.
With the bucket edge held down by the batwing, and the cam lobe out of the way, the shim may be removed and replaced.
Instead of fooling with the lever to press the bucket down for insertion of the batwing, I prefer using the cam lobe to push the bucket down for insertion of the batwing.
2 -- insert batwing;
3 -- hand-rotate crankshaft whereby cam lobe moves away from shim, and allows edge of "rising" bucket to be caught by the batwing;
4 -- remove and replace shim;
5 -- hand-rotate crankshaft whereby cam lobe depresses subject valve bucket and loosens the batwing from where it caught against the bucket rim;
6 -- remove batwing, and go to the next valve.
- angryeric116
Patton wrote: 1 -- hand-rotate crankshaft whereby cam lobe is depressing subject valve bucket;
Awesome, sounds easy as pie! Being an inexperienced engine builder, my thanks goes out to all of you.
1979 KZ 1000 LTD B3
- chonus
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
