timing chain noise
- poohbear
07 Aug 2013 22:17 #600344
by poohbear
timing chain noise was created by poohbear
hey guys I have a 78 kz650 c and I am hearing some clatter in the front end. I think it is the timing chain? any suggestions on problems that would cause that
- Thank you received: 2829
07 Aug 2013 22:56 #600348
by 650ed
Replied by 650ed on topic timing chain noise
Have you adjusted the tensioner using the instructions in the Kawasaki Service Manual? Ed
- Thank you received: 2098
07 Aug 2013 23:53 #600354
by Patton
Replied by Patton on topic timing chain noise
Also, a good running carb sync often substantially reduces cam chain noise.
