want to put a kick starter on my 82 kz750 ltd
  • biker8684
  • biker8684's Avatar Topic Author
07 Aug 2013 01:03
#600217
dos anyone know if the kick starter of a kz650 will work covers look the same if my baterys even 2 volts low it will not start my bike unless i time it right or pop it it starts right up
  • martin_csr
  • martin_csr's Avatar
Re: want to put a kick starter on my 82 kz750 ltd
07 Aug 2013 10:19 - 07 Aug 2013 10:26
#600253
2 volts low is low. The bike needs a good battery to run right.
I prefer checking the battery w a digital multimeter.
If applicable, make sure the electrolyte level is correct (add distilled water - not tap water or acid).
High beam test. Charge the battery, then disconnect the charger. You should have at least 12.6 VDC but the voltage will probably be higher ~13.1+. Turn on the high beam (engine off). The voltage will drop. A good battery will drop to ~12.2 VDC but ~11.85 is okay. If it drops to 11 VDC, the battery may need replacing. If it drops to 10 VDC, the battery is probably shot. The high beam test removes the surface charge & gives a better indication of the deep charge, or something like that. The voltages are the numbers I use. There may be a more accurate set of voltages on the internet somewhere.
PS: a kick starter can be installed, but it is a lot of work, as you have to split the cases.
Last edit: 07 Aug 2013 10:26 by martin_csr.
  • nitrokeeb
  • nitrokeeb's Avatar
07 Aug 2013 11:51
#600272
Agreeed. Two volts low is a dead battery.
1978 KZ1000B LTD w/KZ900 engine
  • SLEEPER650
  • SLEEPER650's Avatar
09 Aug 2013 08:51
#600561
I have installed the kick starter into a 750e motor it will work and is work.
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
  • polarbear
  • polarbear's Avatar
10 Aug 2013 02:21
#600657
I guess you could also just swap the motor with another one with kick starter already on it, but then again, a lot of work, only worth it if you really need to--engine failure.
c
