73mm J piston into Z1R engine
- mrdatsunturbo
- mrturbo Norway
05 Aug 2013 16:21
I got 4 almost new 73mm wiseco piston from a J engine 17mm pin,
will this work in my spare z1r engine ? and what compression will i get?
when i have this piston side by side and wrist pin into both piston ,
it look like the wiseco piston is 1mm taller.
So i want to use this with my ATP turbo set up and what size will it be on the spacer
below cylinder?
Thanks from Norway
below cylinder?
Thanks from Norway
Attachment ipodbilder103.jpg not found
- Powerstroke_fan
Re: 73mm J piston into Z1R engine
05 Aug 2013 16:29 - 05 Aug 2013 16:30
Iam not sure that you will want to run those pistons in a kz bottom end. Like you stated the piston pin hole is taller on the j piston, which will create problems. What is the compression ratio on the pistons? You will want a lower compression ratio for turbo pistons. unless this is a drag strip bike only.
1977 KZ 1000 work in progress
Last edit: 05 Aug 2013 16:30 by Powerstroke_fan.
- mrdatsunturbo
- mrturbo Norway
05 Aug 2013 16:51
Yes i will check the compression ratio and it will be on my street bike
- MFolks
05 Aug 2013 18:42
Kz1000 engine differences:
www.aperaceparts.com/tech/techkz1000.html
- mrdatsunturbo
- mrturbo Norway
06 Aug 2013 12:08
so i checked against wiseco catalogue today and it will not work on my
turbobike. compression is 10,25:1 stroke 66mm, bore 73mm on J engine kit.
The wiseco kit for Z1R is 10,25:1 stroke 65,93 bore 73mm so it will work on carb engine.
I am not shure ideal compression for bike but using plate below cylinder?? everything is possible
but higher compression then i need more fuel
- Powerstroke_fan
06 Aug 2013 15:37
The higher the compression means the hotter its going to run and it also creates more chamber pressures, which will limit you on the street. What some people do is run a j model head on it. It out flows a stock kz head and has larger valves and it will drop your compression by two points. I think ideal turbo compression is around 8 or 9 to 1, if i remember correctly.
- mrdatsunturbo
- mrturbo Norway
08 Aug 2013 10:06
I got a mail from APE about this and if i am doing 10psi boost ,then a spacer
on thikness 020 will do.
If i was doing up to 6psi then the 10,25:1 is good to go.
So i will try this recipt and also change to J head for more flow.
1105cc and turbo will be nice, i guess.
