- Thank you received: 235
What size heli coil kit ngkB8ES kz900?
- trianglelaguna
04 Aug 2013 02:17 #599777
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
What size heli coil kit ngkB8ES kz900? was created by trianglelaguna
I searched around the forum search and saw some stuff..i'm going to use the cheap kit for now and not a timsert...What size so I can buy the tap and heli coil set
It is not stripped all the way but the plug spins right before it will torque down and is getting loser....I am going to do the engine next year and will have it apart to re-do with a timsert if need and just need it to last until this fall really....
I know it is a simple thing but any tips and advice for doing it in place/quick-fix..valves closed...air compressor tip...wax pack the tap threads for catching the grit...go slow back it out...snap the heli holder tab off..lock tight......shot or two of parts cleaner and a ext tip and then blow out the hole a few times turn it by hand slow blowing and repeat...anti seize thread goo the new plug...
am i missing anything other than the size of kit I need to find
Thanks folks
Thanks folks
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
04 Aug 2013 02:19 #599778
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
Replied by trianglelaguna on topic What size heli coil kit ngkB8ES kz900?
is the kit I need ???? depth - .75 the threads are 14mm
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
04 Aug 2013 02:26 #599779
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
No eBay APP ID and/or Cert ID defined in Kunena configurationI bet I can get a cheap kit at a local place...
like this right
like this right
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
04 Aug 2013 11:17 #599811
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
bump....
anyone know for sure what size helicoil (14m x .75 inch?)kit I need for a ngkb8es sparkplug on a kz900 it is just beginning to strip/spin before getting tight now....any tricks
some...help a brotha out please....i want to buy and fix this today....forum search showed a bunch of chit chat and egg throwing on old threads but no exact size
1976 KZ900
2003 ZX12R
2007 FZ1000
- Old Man Rock
- Thank you received: 225
04 Aug 2013 11:19 - 04 Aug 2013 11:25 #599814
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic What size heli coil kit ngkB8ES kz900?
Yes M14 x 1.25....
Got mine @ Checkers Auto Parts, Auto Zone has them as well.... ~ the same price minus shipping so call around....
No issues in using the tool....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 04 Aug 2013 11:25 by Old Man Rock.
- Motor Head
- Thank you received: 391
04 Aug 2013 11:27 #599815
by Motor Head
Replied by Motor Head on topic What size heli coil kit ngkB8ES kz900?
Use the 3/4" long insert.
Grease the Tap, to catch the shavings. Even though they're Aluminum, you don't want them in the cylinder.
Make sure you don't have valves open, might be able to hit the tap if you thread in with that stepped one.
- trianglelaguna
04 Aug 2013 19:44 #599857
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
ok great thanks folks...the 1.25 part was throwing me as I know the 3/4" is the insert, now i get it 1.25 is the 14m thread pitch...duhhh....got the kit today with a few different size inserts and it was 32.00 at a auto place ...and will do it soon...
:whistle: ...this was found last night and my buddy was expecting me in his driveway at 7:30 a.m for spin this morning :blink: ....went for a 50 miles blast,forgot about it at one big set of sweepers... :blush: up to 100 plus at one point and the loose plug stayed in...got done with lunch and started the bike and the plug was rattling around...pst-pst-pst-pst...kinda angle threaded it back real quick and limped home another 15 miles...these old bikes are tough suckers...made it home and in the shed it went till I have time to do more work and fix that plug...thanks all...
1976 KZ900
2003 ZX12R
2007 FZ1000
