- Thank you received: 9
Stuck Clutch
- Spectre1982
02 Aug 2013 20:11 #599583
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Stuck Clutch was created by Spectre1982
I'm working on the KZ200. The engine covers have been off during the rebuild and the clutch basket is exposed. When I pull the clutch lever in, I can see it expand but all the plates stay stuck together. If it's in first and I pull the clutch, try to spin the wheel, it stays locked. I can separate the plates by hand and the wheel will spin. Once I let the clutch loose it locks back up tight. Do I need to take it apart to oil it or will it loosen up and work correctly once it's put back together and bathed in oil again?
1978 Kawasaki KZ200
- Haybus
- Big Al
- Thank you received: 42
02 Aug 2013 20:43 #599590
by Haybus
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
Replied by Haybus on topic Stuck Clutch
I had the same problem. Took it apart and oiled the friction and steel plates and it worked fine. Sat for 8 months during my build and it was locked up again. Took it for a spin by running with the bike and dropping it in gear. After about 5 minutes the clutch freed itself, probably due to warming up the clutch parts and oil.
Alan
Alan
2005 FJR
2009 Hayabusa
The following user(s) said Thank You: Spectre1982
- Spectre1982
02 Aug 2013 21:06 #599591
by Spectre1982
1978 Kawasaki KZ200
Replied by Spectre1982 on topic Stuck Clutch
I oiled it up as well as I can while it's still installed. Already a bit better. I'm sure it will be fine once it gets put back in service. Thanks for the reassurance, Haybus.
1978 Kawasaki KZ200
- Thank you received: 2829
02 Aug 2013 21:12 #599593
by 650ed
Replied by 650ed on topic Stuck Clutch
If the plates are stuck next time you are going for a ride leave the engine OFF, put the tranny is 1st gear, pull in the clutch, and rock the bike forward and backward on the pavement. The plates should free up. Ed
