My piston blew so I am upgrading! Kz1000 to 1100
- steell
Re: My piston blew so I am upgrading! Kz1000 to 1100
01 Aug 2013 19:24
If you're tapped out then you need to skip the 1100 stuff and find another J cylinder block.
The 1100 stuff would be cool, but it won't be cheap.
- Motor Head
01 Aug 2013 21:40 - 05 Aug 2013 16:13The earlier 81-83 1100 from the shaft drive and spectre bolt right on. I've got one from the shaft drive on my 1000 ltd, with a big bore kit as well.lucienmaier wrote: grrrr. some much conflicting info.
Like I said, the head and base gasket are different.
If you get the later GPZ, like everyone said the pistons/ pins are different.
Last edit: 05 Aug 2013 16:13 by Patton. Reason: delete sale solicitation
- lucienmaier
02 Aug 2013 03:20
Well got parts on the way. Stay tuned to see how it all turns out..
--1981 Kz1000m CSR--
--Converted to 1100CC---
- Motor Head
02 Aug 2013 10:29
You'll love the extra torque of the extra CC's
- harleeblue
12 Mar 2015 16:01
I have a 1981 kz1000j and I am also putting 1981kz 1100 jugs on my 1000j bottom end.the only problem I might have I was told is .I might have to file the bottom end a little bit where the jugs slide in the block!!! i am using the kz1100 pistons with the 1100 base and head gasket.!!!! the question i have is the 1000j head going to bump up my compression?or will it be the same if i put the 1100 head on????another question i have does anybody know if the 1100 have a bigger cam then the 1000j?????????????
bradley frantz
- harleeblue
12 Mar 2015 16:05
my jugs 1981 kz1100
bradley frantz
12 Mar 2015 16:43
I'm stuck on the wrist pin question.
- lucienmaier
12 Mar 2015 19:31
Wow I thought I had updated the topic.
lucienmaier.com/elf-stories/preview-of-elf-2015/
- harleeblue
12 Mar 2015 21:45
Lol I'm past the rist pin thing,,, I get it. All my parts I got are all 1981 this includes 1000j ,1100 ......Is there a difference between the two different heads? And what are the difference 1100 head verse 1000 j head
bradley frantz
- harleeblue
13 Mar 2015 05:54
bradley frantz
