miss fire
- dan b
01 Aug 2013 02:28 #599367
by dan b
miss fire was created by dan b
hi guys, engine has break up at 6500rpm- 1977 pods mac 4 into 1 stock electronic ignition.any idear on this? Thanks
- Old Man Rock
- Thank you received: 225
01 Aug 2013 08:27 - 01 Aug 2013 08:30 #599380
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic miss fire
1977 what model...?
Which carbs (26's, 28's, BS34's etc...)...?
Miss fire (ignition/electrical) or carbs falling on face...?
Since 4-1 exhaust and pods, what jetting changes were made...?
Carbs sync'd...?
Backfiring/popping out exhaust during deceleration or loss of power @ 6500...?
What do the plugs & strap look like (carbon(rich), white(lean), 50/50 on the strap etc...
Carbs sync'd...?
Attachment SparkPlugBase.JPG not found
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 01 Aug 2013 08:30 by Old Man Rock.
- dan b
01 Aug 2013 08:46 #599382
by dan b
Replied by dan b on topic miss fire
the bike is 1977 kz 650 B I will check the jets and pull the plugs thanks
- Thank you received: 2829
01 Aug 2013 08:51 #599383
by 650ed
In your first post you stated "stock electronic ignition." Your bike originally had points, not an electronic ignition. You may want to double check to see exactly what is on the bike. If it still has the stock ignition the points & condenser probably need to be replaced. Ed
Replied by 650ed on topic miss fire
dan b wrote: the bike is 1977 kz 650 B I will check the jets and pull the plugs thanks
- dan b
01 Aug 2013 14:07 #599423
by dan b
Ed, I have changed out the points with a late model electronic unit.bike has a set of acell coils.the problem has been the same with all of the stock parts.
- savedrider
- 1975 Z1-B 900
- Thank you received: 1
01 Aug 2013 14:42 #599427
by savedrider
Get right or get left! <*{{{><
Replied by savedrider on topic miss fire
Have you tested resistance on the coils?
