KZ440 slowly tops out to only 60
- KonfusedKZ
Checked compression, it is at 125psi after 3 cranks and will get up to 150psi by 6 cranks.
adjusted value clearance
changed spark plugs
cleaned carbs very well and used a rebuild kit while doing so
replaced the carb diaphragms
put on new carb boots
cleaned the air filter
changed oil and filter
put in a relay to raise the voltage to the coil
replaced the chain (At 12,500 miles)
new tires
rebuilt the forks
replaced the clutch cable
lubricated all the points outlined in the service manual including the timing advancer
lubed the chain every 300 miles
I started to notice the drop in the acceleration and top end at around 12,000 miles and it seemed to get worse after replacing the chain. I'm now at 14,000 miles and I just changed the oil and filter again and cleaned it up a little. I checked the compression again and it has not changed. I did notice my oil level seemed to be slowly dropping since my last oil change and there are no leaks. I'm confused as to where it is going because I don't see any blue smoke coming from the pipes even at high revs. In the air box there does seem to be an oily residue and I figured that was from the crankcase emission control system. From the service manual, "The system eliminates the release of crankcase vapors into the atmosphere. Instead, the vapors are routed through and oil separator to the intake side of the engine." Could there be something wrong with the oil separator and could this cause any performance issues? I also have some exhaust leaks around the baffles due to rust, but that has not changed since it was able to hit 85.
Any help anyone can give would be fantastic because I'm starting to get pretty frustrated. Thanks!!
- Thank you received: 2829
- KonfusedKZ
- Motor Head
- Thank you received: 391
- KonfusedKZ
- Thank you received: 2098
If not already done, would use a timing light to view and confirm that the timing advancer is functioning properly by quickly moving back and forth as rpm is varied by blipping the throttle.
- roy-b-boy-b
- Thank you received: 103
Try other suggestions first before removing the cover.
- KonfusedKZ
Thanks for all the help and suggestions!
- Motor Head
Yuk! :sick:KonfusedKZ wrote: I pulled off the carbs today to take a look in the bowls and the fuel lines for any clogs. It all looked fine till I tested the diaphragms and they snapped shut with no seal at all. I'm glad I can pretty confidently say this is whats causing all my issues, but its weird that my brand new diaphragms would only last 2,500 miles. The last two pictures are two different tears in the same diaphragm.
Will the company you bought those from warranty those, maybe have a better quality set for you? The OEM ones lasted for So many years, and those new ones, well are Junk.
- Nebr_Rex
- Thank you received: 300
The Keihin cv34s on the KZ750/4 ( h/LTD and e/standard ) use the same slides.
Find yourself a rack of four and have 2 spares.
I have no idea if the cv38s off the KZ750b ( twin ) or the cv32s off the later KZ650 will swap or not.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
