kz550 1979 electrical problem. help!!
  • stunter956
  • stunter956's Avatar Topic Author
30 Jul 2013 22:26
#599131
This is wierd, i have my key switch disconnected and even like that my instrument cluster stays on, ive gone thru all my wiring harness and they are all with their respective colors. Maybe im missing one that could be connected wrong?
1976 kz900 "mean green"
  • Motor Head
  • Motor Head's Avatar
Re: kz550 1979 electrical problem. help!!
31 Jul 2013 09:45
#599195
Go to your instrument connections. Pull them, and use your meter or test light on the harness end of those connectors and find which wire/s have power. Record and post the colors.
  • stunter956
31 Jul 2013 10:58
#599206
Will do that today thanx
  • stunter956
31 Jul 2013 12:50
#599216
Brown and red/blue wires have power
  • Motor Head
31 Jul 2013 22:10
#599329
Well Brown is supposed to be switched through the ignition, so if it is hot at the harness end of the instruments. I'd unplug the ignition switch next. Then recheck it. On the wiring diagram, they will show the Ignition switch contacts in each switch position. That way you can test the switch.
Wiring diagram will be here on KZR, under "File Base" upper right corner of this page.
  • stunter956
10 Aug 2013 13:58
#600694
found the problem, my regulator was bad, replaced it and problem solved, thanx for ur imput though
