Engine Oil Level Guage
- Andrew D
26 Jul 2013 15:43 #598411
by Andrew D
Engine Oil Level Guage was created by Andrew D
Can someone upload an image of an oil level gauge with the engine oil correctly filled? According to the picture in this manual, I'll know I'm at the correct level when my motorcycle and garage turn completely black.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
26 Jul 2013 15:59 #598413
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic Engine Oil Level Guage
sounds like valve seals are shot or rings are stuck or shot.... youd have to have that bad boy fulllll of oil and it wouldnt even look right. does your bike have a sight glass? if so half way up is where it should be
- Powerstroke_fan
- Thank you received: 83
26 Jul 2013 17:31 #598434
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Engine Oil Level Guage
The oil level should be between the bottom (low) and top(full) of the sight glass. This is checked with the engine on the center stand. If there is no center, balance the bike and check it with the bike level.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- lushbaugh
26 Jul 2013 17:33 #598435
by lushbaugh
yea the bike should be straight up, forgot to say that lol
- Andrew D
04 Aug 2013 17:18 #599845
by Andrew D
Replied by Andrew D on topic Engine Oil Level Guage
Thanks.
