Carb - Broken Choke Tube - Repair Options?
  • weales
  • weales's Avatar Topic Author
24 Jul 2013 21:23
#598128
Carb No1 on my 1979 Z1000 Mk 11 engine has the choke tube broken off just below where it is fitted to the carb body. (This usually happens when the float bowls are removed and care is not taken to protect the exposed long thin brass tube.) Anyone had any luck repairing this type of damage? Thinking of either carefully drilling out the remaining stub and fitting another (where to get one??) or sweat soldering the broken bits together - need to ensure the repair doesn't block the flow of fuel! Maybe someone has a No 1 carb body they could sell me?
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
Re: Carb - Broken Choke Tube - Repair Options?
25 Jul 2013 09:58
#598188
Brass tubing is often available at hobby shops.
Good Fortune! :) :)
  • z1wiz
  • z1wiz's Avatar
25 Jul 2013 16:17
#598221
That tube is a press fit. If you can get the remaining piece out, one can be sourced from a donor carb and pressed in. I did this on a z1 carb. If that tube is the same as a 77 or 78 KZ1000 carbs, I'm pretty sure I can provide one.
Russ
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
  • weales
29 Jul 2013 21:32
#598992
If I get a donor carb any ideas how to remove the tube without damage, given that it's a press fit ?
I've attached a couple of pics to help identify the carb and tube.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • Motor Head
  • Motor Head's Avatar
29 Jul 2013 21:54
#598995
The hole in the tube its self is the Starter Jet. That supply's the mixture of fuel to the enrichment circuit when the choke is on. So that size needs matching. You can drill out that remainder, possibly just oversize for a new piece of tube from the hobby store. But you will need to drill the fuel jet size also, so you may need to purchase a small #'d set of drills. Replacement of the tube it pretty straight forward. Get the hole so its about .001" smaller than the new tube with a drill. Heat the carb body, and freeze the tube. It will go right in.
The new tube will be hollow its whole length, so you may need to solder the end shut, then drill the jet size.
The following user(s) said Thank You: weales
  • weales
29 Jul 2013 22:36
#599005
Many Thanks!
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
