messed up clutch
- dan123
messed up clutch
22 Jul 2013 22:11
i just finished putting the front end of my bike back together so i jumped on and took a ride through the neighborhood. the bike was having a real hard time getting into first gear, i could get it rolling in the friction zone for a bit but the engine would bog out and stall if i released the clutch all the way. it might have just been that the engine was running weak or something because it seemed to get better before i stopped. anyway, i had not adjusted the clutch properly beforehand so i took out my manual and followed the directions for adjusting the clutch cable. when i pulled in the clutch lever to try it out i heard a snap/pop noise and the lever went slack. i quickly realized that i followed the directions for the wrong model and the process is almost the exact opposite for my 82 550ltd :blink:. i took off the clutch cover and a bunch of small pebble looking things fell out and were sitting at the bottom of the case. i had to stop there unfortunately because the sun was going down and i have to work outside. i assume that those where chunks of friction plate but i dont know anything about clutches so i could be wrong. if any of you know what i messed up or broke that would be really helpful in getting this bike back up and running in a timely fashion. if history repeats itself it will take me forever to figure it out on my own. thanks guys
Re: messed up clutch
22 Jul 2013 22:22 - 22 Jul 2013 22:24dan123 wrote: ...had not adjusted the clutch properly...heard a snap/pop noise and the lever went slack...followed the directions for the wrong model and the process is almost the exact opposite for my 82 550ltd :blink:. i took off the clutch cover and a bunch of small pebble looking things fell out and were sitting at the bottom of the case....
Last edit: 22 Jul 2013 22:24 by Patton.
- dan123
22 Jul 2013 23:42
no everything looked okay on the sprocket side. it was when I opened the clutch cover when the chunks of stuff came out
- Motor Head
23 Jul 2013 10:08Pictures?dan123 wrote: no everything looked okay on the sprocket side. it was when I opened the clutch cover when the chunks of stuff came out
- dan123
23 Jul 2013 10:34
the friction plates all look fine so im stumped, i will try and get pictures out soon
