Getting frustrated
- 80kz550A1
Getting frustrated
21 Jul 2013 17:10
KZ550A1 1980
Okay so just fixed my clutch problem now have another. Didn't ride the bike for about two weeks, go to take a ride with my buddy. Anything past 1/8-1/4 throttle it was cutting out. Figured carbs needed to be cleaned since i haven't cleaned them this year. Found a whole bunch of rust in the bottom of the bowls. Cleaned them all up. Sync them with the wire method stated in the Factory service manual. Bench set the float height with the clear tube. Also installed a spare tank i have that doesn't have any rust guess my other one did that i couldnt see. Installed the carbs and starts up way better and idles better. But that didnt solve my missing problem. All 4 cylinders are getting spark. Im a bit stumped. Guna test the coils tomorrow at work. They are dyna green 3.0 ohm coils and i have a dyna s ignition.
Re: Getting frustrated
22 Jul 2013 00:25
Compression test?
Valve clearances within specs?
- 80kz550A1
25 Jul 2013 19:10
everything is good. dont even know where to start now.I found vacuum leaks between the carb holders and head.i fixed that and still no change. If I roll into the throttle it doesnt miss fire. That was leaning me towards it being the float height but thats within spec. Also am running the bike on prime.
- turboguzzi
25 Jul 2013 20:22
there's cleaning and there is cleaning.... with rust particles in the bowl they could be every where in the circuits, sounds like you need a full disassembly and ultrasound cleaning of the bodies. a bit late to tell that a simple in line fuel filter could have saved a lot of frustration...
dont think your problem would be compression or valve clearances,
was the bike carburating perfectly two weeks ago?
- 80kz550A1
28 Jul 2013 12:58 - 28 Jul 2013 13:03
yes it was running good besides start up had to give it a little gas. now it fires right up! but still running exactly the same as before i cleaned the carbs. i used compressed air to clean out all passages in the carbs. im thinking its something ignition related.i tested the coils and they are fine and so is the dyna s ignition i have installed. really stumped on this one. if i give it easy throttle it will rev all the way up without cutting out. its really odd. any tips on testing the ignition under load some how? Also could the emissions crap cause this?
Last edit: 28 Jul 2013 13:03 by 80kz550A1.
- koolaid_kid
28 Jul 2013 13:01I have to agree with this. There is no telling which passages may be blocked at this point. It is far better to just start over at the beginning rather that trying to patch things up.turboguzzi wrote: there's cleaning and there is cleaning.... with rust particles in the bowl they could be every where in the circuits, sounds like you need a full disassembly and ultrasound cleaning of the bodies. a bit late to tell that a simple in line fuel filter could have saved a lot of frustration...
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- 80kz550A1
28 Jul 2013 13:06
okay well guess i need to find a place that has a sonic cleaner. i have another set of carbs i used for a few parts like a bowl and choke plate. they were very clean and came off a running bike apparently ill clean those up and try them see if anything changes. thanks for the idea ill get back with results
- nickleo373
28 Jul 2013 13:15
Harbor freight sells ultrasonic cleaners. I picked one up on sale for pretty cheap.
1981 KZ550C LTD
"If you ain't first, you're last"
- turboking
28 Jul 2013 15:1480kz550A1 wrote: KZ550A1 1980
rust in carb bowls :pinch: ......... :pinch: you need to address the rust in the fuel tank or you will be cleaning your carbs in a short time again...... no filter made stops the rust from going through the carbs. :S :S :huh: all rust must be removed.....then you can deal with the carbs... :dry: my .02
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- wireman
28 Jul 2013 16:22
Stock up on inline fuel filters and dump a big can of sea foam in the tank,take it out and run a couple tanks of gas through it and see if it helps.
- koolaid_kid
28 Jul 2013 18:54
You can also use a carb dip, such as Berryman's. Around $20 at Walmart.
1983 GPz 750
- 80kz550A1
28 Jul 2013 21:29turboking wrote:80kz550A1 wrote: KZ550A1 1980
i swapped to a spare tank with no rust in it. im surprised the rust got past the very fine screen on the petcock. i have installed a new inline fuel filter.
