rev counter oil seal
  • turboguzzi
  • turboguzzi's Avatar Topic Author
18 Jul 2013 17:17
#597153
anyone knows the dimensions of the typical kawaski rev counter oil seal?
92049 1315 fitted to tons of kaws from 250's to 1300
just will be easier to get it form a nearby oil seal shop
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: rev counter oil seal
19 Jul 2013 01:06 - 19 Jul 2013 01:09
#597238
Did you mean a tach drive oil seal?? That part number 92049-1315 does not sound right. The real common tach drive oil seal for anything from a KZ200 to KZ1300 is 92050-075.
That 92049-1315 shows it only fits only a KMX125. What ever that is.
Can't help you on the sizes, sorry.
1986 RG500G 2 stroke terror.
Last edit: 19 Jul 2013 01:09 by Dr. Gamma.
  • turboguzzi
19 Jul 2013 04:22 - 19 Jul 2013 10:54
#597256
older diagrams might show a different number, but 92049-1315 actually supeseeds the 92050-075
www.cmsnl.com/1980-kz750-h1-ltd_model155...050075/#.UejoY7Jbbw0
they should be the same size and everything
how's the build going BTW?
edit: measures out 6mm X 13mm diameters it seems, anyone can confirm?
Last edit: 19 Jul 2013 10:54 by turboguzzi.
