Valve cover Gasket help!!!
- DBICK666
- 1983 kz750 ltd f-1 (shaft)
16 Jul 2013 17:16
hi i found 2 different part numbers for my 1983 kz750f shaft i think i need 11009-1274 but i seen another one says for my bike but gasket looks different i think it was 11009-1264 do you know with one i need ples help i need to order this asap or does someone have one for sale?? thanks
- Cynjut
Re: Valve cover Gasket help!!!
16 Jul 2013 17:25
11009-1274 is a head cover gasket.
11009-1264 is a clutch cover gasket for a KX-125.
Not sure how this confused you, but the 1274 looks like the part I'd get, assuming you are actually looking for a valve cover gasket for KZ750.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
The following user(s) said Thank You: DBICK666
- MFolks
16 Jul 2013 17:26
If your bike has the Kawasaki supplied Clean Air Suction System(CASS), or known as the smog gear,then the gasket will be different, to allow the ports to clear the gasket.
- Cynjut
16 Jul 2013 17:28
The 1274 part is the one for the smog control valve cover.
1977 KZ-1000 A1
16 Jul 2013 17:29
According to Kawasaki.com the gasket is part number 11009-1274. Ed
Attachment 00000_2013-07-16.jpg not found
- DBICK666
16 Jul 2013 17:47
well the 2 gasket have same part number and on the gasket but one has 4rings in the middle between the two cam the other one just has a closed middle bif that makes any scence im new to working on bikes so bare with me
- DBICK666
16 Jul 2013 17:52
here are the 2 gasket with same part number
16 Jul 2013 18:21
I'm not sure where you are seeing the different gaskets/part number, but as Cynjut said Kawasaki.com shows part number 11009-1264 is the clutch cover gasket for KDX200 and KX125 models.
Attachment 00000_2013-07-16-2.jpg not found
16 Jul 2013 18:26 - 16 Jul 2013 18:39
Give Z1 Enterprises a call, and be assured of getting the correct gasket.
www.z1enterprises.com
www.z1enterprises.com/ItemDetails.aspx?i...X750&item=11060-1603
www.z1enterprises.com/ItemDetails.aspx?i...ZN700&item=SU619-610
Last edit: 16 Jul 2013 18:39 by Patton.
- Cynjut
16 Jul 2013 18:31
CYLINDER+HEAD+COVERS
show both valve covers using the same part. Every search I did comes up with the same part number for each.
If you have CASS (like the bottom picture on the Partzilla drawing), you definitely need the cover gasket that has the extra holes (they are the part that feeds air into the exhaust). If you don't (the cover is solid) you need the one WITHOUT the extra holes.
If your engine doesn't have the CASS system, it might use a gasket like 11023-006, but I just don't know. That's like the gasket without the extra holes you were describing. You need to look at the cover and see what gasket you need.
You didn't post any pictures, so we can only give you the answers that we have access to.
1977 KZ-1000 A1
- DBICK666
16 Jul 2013 19:30
alrght everyone thanks for the info i found my gasket its got the bigger holes in the center of the gasket
